blowing subs
Old Mar 22, 2004 | 06:07 PM
fly351's Avatar
Car: 1996 Camaro RS
Engine: v6
blowing subs
i'm kinda having a problem with my subs. i have 2 1000 watt rockfosgate HX2 12"s, pushed each with a 1000 watt rockfosgate power DB amp. The subs are rated at 500RMS, the amps are rated at 650RMS. The audio shop that built my box is saying that the box doesn't need to be sealed or have breath-holes. I have even turned my amps down half way and they have almost blown once again.
The air-space is also the correct size. A friend of mine says that the box needs to be sealed or have breath-holes. does anyone have suggestions?
Old Mar 23, 2004 | 01:07 AM
onebadwagon's Avatar
PORTS, no breath holes.
how do you know the box is the right size? do you know what distortion sounds like?
if it sounds bad, turn it down.
Old Mar 23, 2004 | 02:02 AM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
from my limited experience with HX2s they seem to perform their best in ported boxes. So if you have the space port your box and you'll notice a big difference in output.
Old Mar 23, 2004 | 03:28 PM
fly351's Avatar
Car: 1996 Camaro RS
Engine: v6
yes i know what distortion sounds like.
i am going to "PORT" the box and see if that doesn't help out.
thanks
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Fanatic1074
Oct 2, 2015 03:47 PM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
