Infinity kappa speakers DISSAPOINTED
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
Well im not runinng and amp yet, but i just put all new kappa 6X9 and 4X6 in there, and well
NO BASS
NONE
lol for the highs, damn they sound good!!! very crisp very clear, even without an amp, im sure that will get much better, but as for some bass there is nothing
i know its probably because our cars are gay and that back speaker well is just too tight, nowhere to make any bass, but they are 3 way very expensive speakers, i was hopin for a little more bump
NO BASS
NONE
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Have you verified that the polarity is correct? If one of the speakers is wired out of phase, you'll lose your bass. If they are wired correctly, those 6x9s should provide adequate bass.
Car: 89 IROC-Z
Engine: 355 TPI
Originally posted by 1991 Z-28
what do u mean by that? if they are on postive neg correctly?
Agreed, it sounds like you have your speakers out of phase... possibly the front two also. I posted a review on the Kappa 4x6 plates here recently and they put out great frequency response. I imagine the 6x9s should definitely be pounding.
Best way to do it is to pull out the headunit with everything wired up. Cut the two wires leading to one speaker. Get yourself a AAA or AA battery and touch the wires to each end of the battery. If the speaker moves outward, the wire on the + side of the battery is the positive wire for that speaker. If it moves inward, then it's reverse; the wire on the + side of the battery is the negative wire for the speaker. Splice the wires onto the appropriate wires on the headunit and you're all set. Repeat for the other three speakers.
You need to be able to see the speakers to do this, so take off the sailpanels and dash pad. I think your opinion will change.
They won't sound like crap... they will actually do what you are describing: cancel out lower notes.
The high notes don't get cancelled as much because of their small waveform.
I helped rewire a friend's subs one time. He said the same thing: the subs sound good; they just don't pound. It turned out he had all kinds of wiring int he wrong spots. I fixed it all up and it pounded hard enough to get stolen a week later.
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I suggest getting some subs.
Thats what I did
I can recomend Volfenhag, they are damn good for the price, eiter them or JL's
Thats what I did
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the kappa's arent going to give you much bass. many of the good aftermarket speakers leave the bass stuff up to subs. there's no way a tiny 4" speaker is going to get anywhere close to even midbass without distorting and sounding like junk. kappa's are great for mids and highs. however, you will need a sub to enjoy the whole musical experience. i'd recommend shopping online for some alpine type-r's, adire audio shivas, jl w3's, or even some dayton audio. there are quite a few different subs that are good for little money.
The Kappa 6x9s will definitely give some bass, just not as much as someone with Alpine subs and Ample Audio amps would be used to.
The way he's describing the problem, it seems like there is more to the issue than the fact that subs will pound harder than 6x9s. If they were 5" or 6" components, on the other hand, I would completely agree about good aftermarket speakers not being designed to handle the bass. The 6x9s were designed to handle most of it though.
The way he's describing the problem, it seems like there is more to the issue than the fact that subs will pound harder than 6x9s. If they were 5" or 6" components, on the other hand, I would completely agree about good aftermarket speakers not being designed to handle the bass. The 6x9s were designed to handle most of it though. Supreme Member
Car: 00 TA, 91 Formula, 89 RS
Originally posted by PhAnToMs
jl is all about sound pressure not sound quality
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Originally posted by FyreLance
... according to whom...?
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
Ill put my sound quality up against anything thats costs less than twice the price of my JLs Supreme Member
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Originally posted by 2.73's Suck
yea right
yea right
Ill put my sound quality up against anything thats costs less than twice the price of my JLs Lets see you subs then
Engine: hamsters
2 10's that are the "powerwedge" design, totaling 360 bucks(from the store), but I only paid 50 bucks for the 2. I listen to every kind of music imaginable (except country cause it sucks so bad) and Ive heard everything from 15's to 8's and nothing compares for the price. SPL doesnt even come into play, thats what 15's (or 18's) with gigantic rubber surrounds are for. I dont go for loudness, just quality, my amp is at 1/2 of the gain. The only thing I like more than Camaros is music, thats why I have JLs. Or if i was rich....
Car: 1988 Iroc & 2002 WS6
Engine: 5.7 in both
Transmission: manual in both
I don't know if there's a problem with your setup, but I just put in all new infinity speakers (dash and rears) and they sound amazing. I had planned on adding 1 10" in the back because I had heard that infinity didn't deliver much bass, but they don't need it. However, it will add nice fill down low.
Good luck!
Good luck!
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
Oh wait... you were serious?
yea right
yea right
Ill put my sound quality up against anything thats costs less than twice the price of my JLs Thread
84 TA NV
Sep 6, 2015 08:02 PM
