GTA subwoofer gain control switch
Old Mar 28, 2004 | 03:38 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i got a switch from a 88 gta and i need to know what the gain contgrol switch pins are, or just what wire colors go to what pin on the back, there is 6 pins.
anyhelp would be greatly appreciated
Old Mar 28, 2004 | 08:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the pic! I always wondered what those looked like! Unfortunately I can't help ya, but man, that thing looks hot!
Old Mar 29, 2004 | 08:05 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
I got that control in my TransAm. It worked fine with the stock delco deck however it stopped working when I dropped the Pioneer in it.
Old Mar 30, 2004 | 11:30 AM
Car: 91 formula
Transmission: t5
can you unscrew it and take a pic of what wires connect onto what pins on the back of it, and then i can help you hook it up to work with your pioneer deck
Old Mar 30, 2004 | 03:06 PM
ThraxXx's Avatar
Umm...unscrew it...how exactly would I go about doing that. The switch is literally mounted on the dash..nice flush mountage.
Old Mar 30, 2004 | 05:11 PM
Car: 91 formula
Transmission: t5
you have to take off that trim panel of the dash, it just a few screws
Old Mar 31, 2004 | 04:33 PM
Car: 91 formula
Transmission: t5
anyone ?
my chiltons has nothing, and i relaly wnat to get this wired up
Old Mar 31, 2004 | 05:13 PM
ThraxXx's Avatar
sorry d00d...
I am really unfamiliar with what screws to remove to get behind it. If you were closer I would let you do itto get the info you needed but as for me I have no clue when it comes to removing a dash.
Old Mar 31, 2004 | 07:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You'll need a 7mm socket... look at your dash gauge panel just before the lip of the black dash pad. You'll see a bunch of 7mm screws; remove 'em.
Then go below the "ridge" that the sub control, hatch pop, and defog switches are on. Underneath, you'll see more 7mm screws; remove those too. Now the dash pulls away from the gauge plastic. It's a great chance to clean your gauge plastic as one big "rectangle", instead of individual circles.
There's really no way to mess anything up; just don't overtighten the screws when you put the dash panel back on!
Old Mar 31, 2004 | 10:13 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
not trying to outsmart anyone here, but the hex screws are actually 9/32" although the 7mm socket will undo most of them too....those two sizes are almost exactly the same size but the metric is slightly larger. Although GM does utilize quite a few 10mm hex screws mostly for the body paneling and misc interior trim.
As for the gain, I'm not sure it does any of that. I'm pretty sure that it is a regular ON-OFF switch. you can wire it to turn the remote signal on or off if you are using amps. If your car actually has the stock sub amp....it is crap anyways I wouldn't even bother with it. The amp is located somewhere under the dash near the passengers side. It's not too hard to get to, but you do have to dismantle some stuff.
Old Mar 31, 2004 | 11:02 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
7mm is smaller than 9/32"..
9/32" is 7.14mm
7mm is, well, 7.00mm
7mm hex will fit the screws nicely... 9/32" will work, but only if its a six point..
Old Apr 1, 2004 | 09:15 AM
Car: 91 formula
Transmission: t5
CAN ANYONE GET A PIC ?
Old Apr 1, 2004 | 11:12 PM
Engine: 2.2
yup, 9/32" is 7.15375 mm or .28125".....my bad
'91, all you are working with is the blue remote wire from the deck. cut it and connect each end to terminals on the switch, test the swicth for continuity.....don't let the copper in those wires ground themselfs while the radio is on. If you aren't using and amp, then none of this applies....there is nothing that switch will do for a HU besides turning the dimmer lights on or off maybee....
DOOOOOO not hook up the Pioneer to the factory amp!!! leave that entirely out of the equation. infact, run new wires to the rear speakers if it is not too much trouble for you.
Old Apr 1, 2004 | 11:16 PM
Engine: 2.2
the plug should fit perfectly over the switch. it will be connected to the HU harness and also a small metal box with DELCO stickers on it, a little to the right behind the dash.....if it's not there....fooougetabout-it
Old Apr 2, 2004 | 01:16 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
A-red
B-ppl
C-wht
D-blk
E-gry
F-pnk
Old Apr 2, 2004 | 05:53 AM
Car: 91 formula
Transmission: t5
Originally posted by Justins86bird
A-red
B-ppl
C-wht
D-blk
E-gry
F-pnk
thank you, could you elaborate on that a bit and say teh position of the pin, or what the small one is and how they go from there, i have a bare switch and that is it, there is no a, b,c,d,e,f on it
i am adding just teh switch to my 91 to control my amp, it will have nothing to do with a factory uq7 setup, i will also post pics when done
Old Apr 3, 2004 | 06:38 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Contact Tom at www.houseofcamaro.com He's got the connector and harness for the switch. With the connector you'd know which colors are for which prong, or you could even splice your wires into the connector's wires and simply plug it onto your switch--nice and clean.
The pic of mine didn't come out was well as I'd hoped, but here's what it looks like in the dash. But sorry, no, I'm not taking my dash apart to findout where the wires go, lol. Try Tom. He's a great guy, and he's got just about everything.
Old Apr 3, 2004 | 10:58 PM
Engine: 2.2
What do you want the switch to do with your amp? turn it on or off? That's easy ****. what do you need the colors for?
Old Apr 3, 2004 | 10:59 PM
Engine: 2.2
what kind of amp do you have? does it have remote bass boost or gain control?
Old Apr 3, 2004 | 11:21 PM
Car: 91 formula
Transmission: t5
it is a kenwood amp, and no it does not have factory gain control, so i am adding it, all you have to do is to splice some rca's into it and poof there you go, i just need to know what pin does what
i can get eh wiring harness if i absolutley need to get it, but i was hoping that someone on here would know waht it is, but i guess i was wrong, so i will have to drive to the junkyard and see if the car is still there and just cut the harness out of it
Old Apr 4, 2004 | 12:33 AM
LAFireboyd's Avatar
Umm, why didn't you take the harness too?
Seriously, call Tom. His number's toll free, and it's on his website. www.houseofcamaro.com He's really a cool guy. If nothing else, maybe he'll at least tell you the sequence of the colors in the connector, and it'll save you a trip to the junkyard.
Or if you still don't have the info by tuesday, I'm going to see Tom to get a few things for my car. Let me know, and I'll look at, and maybe take a pic of, the connector for you.
Tim
Old Apr 4, 2004 | 09:57 AM
Car: 91 formula
Transmission: t5
ok that would be awsome i will let you know
i have to go to the boneyard to get part for my truck, but it has been raining for like a week straight, i dotn wnat to go till it stops, if it ever does stop then i will get to go,but it isnt looking good till the end of next week, so if i dont get to go i will let you know.
Old Apr 4, 2004 | 10:10 AM
Engine: 2.2
the switch is basically an ON-OFF switch. the multiple pins are of two separate switches, one is like a Single Throw double Pole, The other is just on-off if I remember right. However it's configured, it simply allows current to pass or not to pass between certain pins. There are only two modes, On or Off.
You can solder the wires directly onto the switch, or just use standard spade connectors. I thought you were just running the 12v remote wire through two of the pins on the switch. This would allow you turn your amp on or off at your command as long as the HU was on. If your talking about running your stereo signals from the RCAs through that switch, that's pretty much useless. If you use the switch to connect or disconnect the remote 12v lead, you only need two pins on the switch which open or close with the pushing of those buttons. Any two that do that will work, probably a pair right next to eachother. THe rest you can leave disconnected.
If you 'experiment' with the 12v remote lead, nothing much can go wrong, as long as you aren't shorting those wires to ground. The worst that will happen is your amp will turn on or off as you swicth leads and find out which ones work in conjunction with the switch position. Do not for any reason, run grounds and positive voltages through that switch, just the 12v + remote (low current) wire.
What you're doing sounds adventurous, but if you aren't sure of the pins or how to figure out, you shouldn't attempt to modify the funtion of your amplifier at all. I'm not trying to insult you, I just don't want you to destroy you equipment for no good reason. I'm an electronics tech myself and I would not mess around with the amp itself, the best you can do is hook it up and set it up properly. Using the switch as a remote on-off switch is all I would attempt to do with that. That is a perfectly reasonable 'trick' because it utilizes stock controls, yet electrically does the same thing that was intended.
If your're talking about desoldering the gain potentiometer and adding an RCA loop to relocate it somewhere else, please let me know how that works out. It would be easier to add something inline with the RCAs at the dash, but that's just MOP.
You could just put the amp under the seat with a long flathead screwdriver stuck in the gain dial.....sticking out far enough for you to just reach down and turn it from the driver's seat!
Although, the all time classic would be to mount a flange over the gain dial, utilize a long speedo cable....allowing you to turn a **** within your reach and thus turning the gain on the amp in the trunk space....That's high tech!
Old Apr 4, 2004 | 10:30 AM
Car: 91 formula
Transmission: t5
i dont know if i am explaining what i would like to do very well, what i wnat to do is possible and i know that people on this board have done it, there was a thread on it
Originally posted by loomdog32
Ok here we go:
The basic idea is to first convert your 2 (or 1) RCA plugs coming from the back of your head unit to a single wire (and ground), put it through the switch/slider, and convert it back to RCA plugs.
There might be differences with what you want to do and what I did:
-I have a stereo pre-amp output on my head unit, but the slider only supports mono
-This is probably only good for low frequency signals, anything high-frequency will probably pick up some noise when it goes through the slider. Besides, since you can only do it in mono, it wouldn't be worth sacrificing stereo for.
-You can also hook up the sub on/off switch in line to the amp. You'll now have a control for whether or not you want the sub on AT ALL.
Ok, I'll start by going over every wire coming from the switch/slider, and then briefly talk about the RCAs, the rest'll be up to you.
Grey-ParkingLight(+) if you already have this switch in your car, just leave the grey alone, its the positive trigger for the light inside the switch. It'll come on as backlighting to the switch when the dash lights are on, just like the defroster and fog light buttons.
Black-Ground(-) also easy, but we'll also be hooking the ground from the RCAs into this later...
Pink-Amp-on trigger(+) This is commonly the blue lead from the aftermarket head unit, telling the amp in the trunk to turn on when the radio is on. By interupting it w/ the switch, you can turn your bass completely off, for whatever reason you might want. (This has come in handy for me for listening to Opie and Anthony no bass needed for talk).
White-Output to Amp to turn on (+) This is the output of the previous wire, and should continue on to the power-on connection on your amp.
Ok, break for the RCA part.....
All you have to do is connect the RCA's tip to the signal wire and the sleeve to ground. It'd probably be best to get a 4-pack of female RCA connectors from radio shack and attach them with small foot-long leads to the switch, that way you can disconnect the switch in the future easily.
Purple-BassIn (+) Take the tip of the RCA and connect it to this wire. this is the input to the slider. When the slider is all the way up the amp will get the full signal of whatever is coming from this wire. If you have 2 RCAs (left and right) coming from your head unit, you can combine the tips of both the left and right RCAs, as well as tieing all the grounds to black.
Red-BassOut (+) The same as purple, but now the signal is coming out of the switch and going to whatever RCA cable that leads to the signal input of your amp. If you need to run stereo inputs to your amp (even though your signal is now mono anyway), you can split this wire to both the tip of the left and tip of the right with no problem.
Ok that covers every wire and their function. If you have basic car-audio knowledge you probably won't need to read more than the first sentence for each wire before you get the idea
Questions, comments, and opinions welcome I hope this helps at least someone
This was origionally posted by Jim 86 Bird in the Body and Interior forum.. just thought i would bring it over to this forum..
this was what i am planning on doing, and mounting it in the top of the ashtray lid since i have a 91 and there is no psot for it on the dash, since i am customizing the top plate anyways i figured why not do it when i am putting in my b&m mega shifter
since my amp has high level inputs all that i dont even have ot convert back to rca's once i leave the switch all i have to do is run the high level wires back to the amp and do it that way. it will be much easier than converting back to rca's, which is not the problem, and be much cleaner than running rca's.
if it does not work then no big deal, i will just take everything out and run it how it is supposed to be run, but if it does wrok then i have something that i can be proud of. if it sounds bad from going thought hte switch then i can take it out, but it not even better.
here is my lay out for what i have in my car
pioneer premier 840 deck with front, rear, and sub outputs going to alpine eq, to the amp, which will go to the speakers obvously. if i can get the switch hooked up then that is awsome and i can do away with the eq, and have my deck installed with a real build up kit and not a hacked up, sloppy one making the eq look like crap when it is installed. it will also be alot cleaner and simple looking and not so congested.
Old Apr 4, 2004 | 11:18 AM
Engine: 2.2
Sounds good, but nevermind the wire colors...know the function of the wires.
No wonder there could be noise...is talking about using a headlamp dimmer or something...!? ..odd
even connecting your L & R signals together doesn't seem like a good idea without something to isolate the two. Why not just get a high quality Dual potentiometer and mount it right under your ash tray lid if that's where you want to put it. The ugly silver spline shaft and lock nut will be visible, but you can add a **** if it comes with the dial (potentiometer). Cosmetically it will look fine with a plastic **** over it. Don't use a 4x RCA radio shack board. instead, get an RCA female ended wire, on both ends or buy the tips with a length of cable...whatever is easiest. Solder the wires directly on to the terminals of the pot. grounds are common, L & R separate ofcourse, but the input connects to one end of the resistor, the output connects to the wiper arm terminal . Now you have a mounted stereo gain dial and two pairs of female RCA cables dangling underneath ready to connect to your RCAs... also ground the casing of the pot, if it is not already a part of the grounding terminal. Please review a schematic, so you can see what I am talking about.
don't use the high level inputs for anything, they are not clean, trust me.
I wouldn't even add connections, I would splice it into the cable that's already there. if you did it right, there would be no need for removing it. You might want to have the RCAs there, just incase you don't like it.
Old Apr 5, 2004 | 08:45 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Ok here we go:
Hope you don’t like stereo.
I’ve posted about this method before. If you do it this way you will loose 20-90% of your stereo separation (depending on manufacture/model of the HU) for the speaker outputs on your HU. Most (almost ALL) HUs do not use any isolation for the per-amp outputs, just a 470 ohm resistor and a muting transistor. That means if you tie the per-amp outputs right to left, some of the signal from the left WILL be feed into the right input of the internal amp, and some of the right WILL be feed into the left input of the internal amp. You will NOT have the same stereo separation; the amount of separation you lose will depend in the make/model of the HU. The right way to do this would be to make a dual op-amp circuit and use the “gain control” to control the gain of the op-amps. That way you will maintain your right/left separation, not to mention that doing it this way you can make you’re 1V per-outs 5V or more pre-outs.
What is the model of your HU? I may be able to look it up and tell you how much separation you’ll lose, and the best way around it.
Old Apr 5, 2004 | 11:44 AM
Car: 91 formula
Transmission: t5
pioneer premier deh-mp840p
Old Apr 5, 2004 | 01:01 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I wonder why no Camaro came with the "Preimum Sound" option?
Old Apr 5, 2004 | 02:18 PM
Car: 91 formula
Transmission: t5
guess you camaro guys weren't special enough
Old Apr 5, 2004 | 03:19 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
DEH-P840mp? Let me check the service info, you may luckout on that one and be able to get away with it.
Old Apr 5, 2004 | 04:09 PM
Car: 91 formula
Transmission: t5
yeah i might have gotten the mp and p backwards, not sure
Old Apr 5, 2004 | 06:20 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Guess so, thats messed up. I guess we did not get the sounds, just the better looking car.
Old Apr 5, 2004 | 07:53 PM
Car: 91 formula
Transmission: t5
thats funny
anyways to keep the thread on topic, i wll be going to the boneyard this weekend i guess to get that harness and hopefully getit hook up to, then iwill let everyone know how it sounds.
Old Apr 6, 2004 | 02:51 AM
Engine: 2.2
That Op Amp sounds like a great idea! especielly since some of the Pioneers don't have much RCA voltage.
You can probably find kits at an electronics store (not radio shack) ready to go, it's more fun to do it from scratch though.
Old Apr 6, 2004 | 07:20 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I have to take back all the negative thoughts in my first post, you luck-out with that HU. In that model Pioneer used a separate line driver for the 4V pre-amp outputs. This IC will give you the isolation you would need to do this and not lose your stereo separation. Just use only the sub-outs (like you would use any other output). You even get and 82 ohm resistor on the output so any difference in signal right to left shouldn’t be a problem, but it wouldn’t hurt to use some a 100 ohm resistors on the output (one each on the center pin of RCA). Your EVTC IC may thank you later by not dying, but I think you’ll be OK with out them.
But on 95% of the HU on the market now you WILL have the problem I described before.
Old Apr 6, 2004 | 08:47 AM
Car: 91 formula
Transmission: t5
this is going to my rear speakers.... not a sub
well it is going to the rear speaker for now, but if i can find the right deal on the sub i want then i might ad one, but for now i am not putting a sub into my car. I have grown out of that phase
Old Apr 6, 2004 | 11:32 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Then you will have NO stereo separation from your rear speakers.....
Old Apr 6, 2004 | 04:30 PM
Car: 91 formula
Transmission: t5
well i made it to the yard today and got the harness, also got a stereo surround with teh premium sound badge on it
i will wire it up and let everyone know how it is
worse comes to worse i have to take it out...
Old Apr 6, 2004 | 05:27 PM
LAFireboyd's Avatar
Cool. I'm glad you got it. I was at House of Camaro today, and Tom didn't have them afterall. I must've misunderstood him. He's HAD them, but he doesn't have any now.
Apparently others have done what you're trying to do now--use the factory switch to control their aftermarket amps.
Old Apr 6, 2004 | 05:33 PM
Car: 91 formula
Transmission: t5
i actually found another one iwth a harness, so now i have 2 and 2 harnesses, guess i can hook one up to the sub in my truck:lala:
or i can wire is so i use both for the same amp, the two switches control the right and left of the rca's
i can wire up the switches so that only one turns both off, if i do this then i should keep my stereo right ?
i just need to find a spot to put both of them now.
i was thinking center console, any suggestions >?
Old Apr 6, 2004 | 05:55 PM
LAFireboyd's Avatar
In the pic above of my dash, see that lower dash section that holds the switches? Looking at the pic of your interior(on your website), I see something similar next to your steering column. It looks empty. Is it? Could you cut that piece and and mount the swithes in it? It would look stock, it would be a convenient space, within reach, and it would be safer than possibly messing up the console shifter plate, I think.
Old Apr 6, 2004 | 06:10 PM
  #42
Car: 91 formula
Transmission: t5
i will have to get a updated pic of my dash
that piece that goes over the radio where there is only 1 swtich in the pics now has 3, i added fogs, and defroster hatch so i got the factory buttons, and the part that is right under/next to the colum has a thick metal plate behind it, so it would be really hard to cut into
i was thinking of drilling a few small holes into the inside of hte console, and just zip tieing the swtiches ot the inside of that, but i want to find a better way to do it.
Old Apr 6, 2004 | 08:09 PM
  #43
Engine: 2.2
You might as well wire up an Optimus equalizer while you're at it.
I could tell you why that wouldn't sound good, but I want you to see for yourself.
Old Apr 6, 2004 | 08:29 PM
  #44
Car: 91 formula
Transmission: t5
ok, i will do it and see how it sounds
the worst that happens is that it does sound bad and i take it out
where can i find the op eq ?
Old Apr 7, 2004 | 10:46 AM
  #45
Engine: 2.2
No, No, leave the Optimus out of there. I don't wish you bad results, but what your doing with the RCA cables and everything, is not the makings of a good sounding stereo system in my opinion. You may do it and have no noticable problems, but that's just luck.
To give you a rough idea, you are comprimising the shielding in the RCA cables and putting the signal through an old crusty switch for really no good reason at all. The 12 remote lead will turn the amp on and off and it won't affect the sound quality as long as it keeps the amp on.
Old Apr 10, 2004 | 03:07 AM
  #46
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! Okay, the neighbors have you to blame. I ran outside in my boxers, took out a screw, came inside, and measured it with my dial calipers. On two sides, I got 7.00 mm, on the third side, I got 6.88mm.
Not that I'm **** or anything but you made me curious!
I think this qualifies as "time for me to go to bed"
89GTAOz
May 16, 2020 09:31 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
Street Lethal
Aug 13, 2015 08:28 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
