amp in the well?
Old Apr 9, 2004 | 08:38 PM
87LG4FORMULA's Avatar
Car: 87 Formula/ 87 IROC-Z
Engine: LT1/L98
Transmission: modded700R4s
Axle/Gears: 3:23 posi/?posi
amp in the well?
Would the amp go best in the bottom of the well or should i put in on the inside "wall". Any concerns with mounting in the well, no subs yet but with this amp (Pioneer GM X374) maybe a little 10" in a small box down the road, for now it is just for my 6x9s.
Old Apr 9, 2004 | 09:32 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I put mine on the bottom.On a wood board covered in matching carpet.Theyre out of the way & out of view down there.
Old Apr 10, 2004 | 01:31 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
yup, i have two amps flush mounted in a fiberglass box that holds a single 10.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
