Amp recommendations
Old May 7, 2004 | 01:36 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Amp recommendations
I need a recommendation for an amp to run a JL 12 w3. Its an older one, not the newer versions, but no more than a year and half. Looked it up and optimum running level is 250w. What would you guys recommend for a fairly good priced amp, that will be what I need. I also need to be able to split the amp out to 2 6x9s that need about 100w a piece.
Thanks in advance guys...
LoL... and keep it simple, I don't know didly about audio stuff...
Old May 7, 2004 | 03:18 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
if you dont want to spend too much, go onto ebay and look at some used us acoustics, kicker, mtx (try to get the blue thunder amps if possible), older rockford fosgate. i had gotten an older mtx blue thunder amp for $75 and it was build like a tank (same amp went for closer to $300 3-4 yrs prior). for something new, the jbl amps are really hard to beat for price.
onto the speakers. no need for 100w each. it would be a waste. you dont need any more than 50-75 watts a piece. since you seem to want one amp, you're gonna want to find a 4-channel amp and bridge two of the channels for the sub.
most importantly, whats your budget? how much are you willing to spend?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
