anyway to get the optional subwoofer switch for a GTA
Old May 7, 2004 | 10:45 PM
comatose 88 WS6's Avatar
Car: Chevrolegs
I have an 88 GTA, and Ive noticed on the edge of the dash there's one last place for a switch. In one of the other posts it shows that it held a factory optioned speaker/subwoofer boost switch. Is there anywhere I can get that switch, or is it near impossible to find? Id use it to control the bass boost on the amp to my subs (sounds like a good idea to me):rockon: So, any ideas on where to start looking?
Old May 8, 2004 | 12:42 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
That switch has been discontinued by GM, so the only ones avail are used. Maybe a junk yard or ebay will have one.
Old May 8, 2004 | 08:02 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I've got one from my old 88' bird.. (the one with the gain button and slider).. I also have the factory amp and harness.. Don't know what to do with it now..
Old May 9, 2004 | 08:19 PM
Car: Chevrolegs
you dont say.....would the switch mount in easy? what would you want for it? lol
Old May 11, 2004 | 06:42 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
you should be able to adjust your woofer through your head unit. I know clarion and alpine you can do it. Along with prolly anything with a subwoofer channel. As far as gain goes...Will it even work with a aftermarket amp? Why dont u just buy an amp that has it? Or rig something up.
nate
Old May 11, 2004 | 03:38 PM
Car: Chevrolegs
I know head units can control amp boost.....I was planning on using the stock switch to run the variable boost available on some amps, such as kicker or RF...
Old May 12, 2004 | 08:53 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Originally posted by comatose 88 WS6
using the stock switch to run the variable boost available on some amps, RF...
Good thought, any one got one of the controls that can check the resistance? I can compare that to the RF remote. Keep in mind that most remotes (like the RF) use two variable resistors. Kenwood uses a switch to add 6, 9, and 12 db.
89GTAOz
May 16, 2020 09:31 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
Chuck84TA
Aug 27, 2015 11:14 AM
TA8487
Aug 16, 2015 12:21 PM
