Quick Bose question
Old May 12, 2004 | 04:53 AM
Genesis98's Avatar
Car: 88 Camaro SC
Engine: 2.8 ->305->350
Quick Bose question
Okay I know to use the deck, and kick panels you need to have the bose head unit, but do you require any kind of special wiring for this or can standard wiring work also are the speakers in the sail pannel and dash any different?
Old May 12, 2004 | 10:39 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You need more wires -- each BOSE speaker has it's own amp and it needs power / ground wiring. 2 for the speaker and 2 for the amp make 4 wires to each speaker.
the BOSE system also uses a "common ground" and a shielded ground wire; make sure you have a wiring schematic before starting this job !
No - the sail panel speakers and the dash speakers are not compatable with the BOSE system.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
