building own "box"
Old May 21, 2004 | 04:49 PM
ajmcmahon's Avatar
Car: Pontiac Trans Am
Engine: Stock 305
building own "box"
i recently bought 2 used 12 inch JBL subs, the and the box is HUGE, took two guys to get it to fit in the back of my T/A to take it home..... but the question is.......
i want to take the speakers out, buy a peice of thick pressure board ( plywood ), cut it out to the shape of my trunk around, cut hole for speakers, make some sort of mounting device to keep it up. will this work , or do i have to actully make a 3d BOX, or will the air from my trunk space be good enough?
does anybody have pictures of what im talking about ? how did you guys mount it to stay up? etc.
Old May 21, 2004 | 04:51 PM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
what you want to make is a plate, very bad idea. Stick to a box if you care what it sounds like.
Old May 21, 2004 | 04:56 PM
ajmcmahon's Avatar
Engine: Stock 305
so the whole " using the air from the trunk space " therory is nonsense ?
Old May 21, 2004 | 10:13 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
i have to argue with you on this one i just got my "plate" installed i used 3/4" particle with a 1x1 on the front and back for exrat support. However i mounted mine in the very bottom as teh bottom rectangular area came out to jsut the right amount of airspace. Right now the amp isnt tuned and the speakers are about 4 hours old and it frickin pounds. I think how i got away with it is the board fits super tight into the bottom so it doesnt reall leak air. Sounds awesom and looks sweet. I'll post pics tomorrow afternoon. I'm runnign two fosgate 12"'s with a 900 watt amp and lightning audio 8awg wiring. It bumps liek i didnt expect it to
Old May 22, 2004 | 01:28 PM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
The only way i can see it really work is if completely seal the whole well. That would kinda be like a infinite baffle setup.
Old May 22, 2004 | 01:54 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Like said, it has to seal ..
I found those a long time ago.. so here ya go
Old May 22, 2004 | 05:38 PM
ajmcmahon's Avatar
Engine: Stock 305
i think im just gonna keep the box in the back seat, like so.
Old May 22, 2004 | 07:06 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
If that dosnt affect the way you use your car, I use my back seat for just temoprary storage, so I couldn't live with that.
Old May 22, 2004 | 07:20 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
im with you except i have t-tops and friends... j/k. but my car has had 4 passengers in it a couple of times and a box make that hard... the rear dip type box is what im going with
Old May 22, 2004 | 07:38 PM
Car: 91 Camaro RS
Engine: TBI
Heres mine with the bottom of the well acting as my "box" finally go tmy amp tuned in right and this **** pounds
Old May 22, 2004 | 07:43 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
i prolly woulda put the amp along the side wall by the spare tier door
Old May 23, 2004 | 12:31 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I bet it would sound better in a box....Me spending all my time and money on making a fiberglass box was my best investment stereo wise...Sure yours sounds good, But it eould sound better in a box
Old May 23, 2004 | 06:52 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I am totally wit you on that, I have had my car stuffed full of people before.
Old May 23, 2004 | 04:20 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yeah well ive seen a camaro with 8 12s in a wall... i dunno but having 4 friends in the car kinda sux as it is and i have long legs so there is like 2in of space in between the back of mah seat and the front of the other... i cant see filling up what little useful space with sumthin that can be put all the way in the back anyways
Old May 24, 2004 | 11:41 AM
Car: 91 Camaro RS
Engine: TBI
Plus it just looks better in a nice setup in the back. I think just laying it in the back seat looks "half-assed" Although i'm also the person who cant have a single wire showing anywhere through the system.
Old May 24, 2004 | 12:07 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
you better not see mine then.. i have the sub winr to the 6x9s harness( ripped that suck right offa the speaker..) the monster wire i used comes outa the sail panel that covers the speak and right to mah sub. lol
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
