speakers cut out
Car: 91 Z28
Transmission: 4l60e
speakers cut out
hey guys not too long ago my spekers stopped playing (front and rear) everynow and then they work but sometimes when i go over a bump they cut out and stop playing anybody know what this is or how i could fix. i have a pioneer cd player dont know the model though
Car: 89 IROC-Z
Engine: 355 TPI
Get the model number.
Check ALL of your speaker connections. All it takes is one of them going to ground or B+ and all the speakers will cut out. DON’T use the radio till the problem is fix, it could and probably will kill the HU if you let it go. FIX IT NOW!
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
The only time I've experienced that problem was when the engine ground strap broke. So I took a battery cable of suitable length and ran it from the A/C bracket to a bolt on the fender. No more problemos
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
id definatly say you have a bad connection on your speakers or your cd player is skipping really bad..LOL...but you need to check all the connections on your speakers and your head unit and make sure they are good and not grounding to something else like said above
Car: 91 Z28
Transmission: 4l60e
ok guys see here is the problems about checking the wires. the guy i bought the car off hooked up the hu and it looks like he did a hack job wires are all spliced and i have no clue where the wires go and it is hard to get at them.
how can i check the ground,speaker wire,power wire and all the other stuff mentioned in the previous replies?
get a digital multi meter and check the wires one at a time is about all you can do or see if trickster on here has a wiring diagram for the factory wires and then check the wiring diagram for the head unit off the net by looking up the partnumber
