Low Voltage due to stereo
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
My Volt guage kept dropping into the read when i was in traffic had my battary charged new alternator etc. Any ways i took it to autohell and had them run a electrical test. I had them do it with the stereo on and when bass would it hit would drop from 14 volts to 10 volts at idle. When i had the stereo off it would stay at 14 volts.
I have heard good and bad about frad caps some say they work others say they dont. Would a cap help my situation? I dont want to go and add extra battarys etc jsut a easy fix. I have a 600 watt kenwood amp for my subs and a 400 watt kenwood amp for my regular speakers. I am running 4 guage wire all the way back.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The only thing that will help is a higher output alt. More batts helps only when the engine is off, and place a larger load on the alt while the car is running. A cap will only help if you alt is big enough to handle the load already, which it appears it is not.
you think you have a 160 amp alternator anyway.
if that thing was putting out 125 at idle, you wouldnt be having these problems, unless you haven't upgraded the battery hot/ground, and alternator ground, as well as engine/chassis ground.
that stuff isnt going to have THAT much of a difference, most likely.
adam
adam
I havent upgraded any of the wires at all all the connections are stock. Would the big 3 that i have read make a big enough difference so i wold not need a cap?
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I was was going to tell you, RS, yes you have bad connections.
You can try to clean the connections, but upgrading the wiring is the right answer.
I saw a show vehicle at a sound shop with upgraded grounding and alt wire. It was a good example of what it should look like, regular 4 guage with gold plated terminals....simple enough. It looked cool, but I would cover it with wire loom too, since it can get hot in the engine bay....looks more 'stock' too, to prevent potential for theft.
db057
Aug 11, 2015 10:11 PM
