No sound
Old Oct 6, 2004 | 09:59 PM
philapino18's Avatar
Car: 88 Camaro
Engine: 305 TBI
No sound
Wired up a JVC hu today and went to try it out and I had no sound , but I the unit did in fact have power, it turned on, found a radio stat ion, and I watched the equilizer going, so in my mind I should have sound. I then doubled checked the speaker wiring, and made sure that the connections were right, everything checked out.
To my knowledge, even with blown speakers you will still, get something coming out. I don't know. I'm going to rewire the front speakers with new wire tomorrow, hoping that maybe my wires are jacked up.
Plus the hu doesn't have a mute, I already looked.
Any help would be greatly appreicated.
Old Oct 6, 2004 | 10:02 PM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
You're on the right path, seems to me somewhere along the stock wiring is cut/grounding out somewhere. I know in mine, if even one speaker is grounding out (wire touching body/metal) none of the speakers will work. So check all the wiring over again. There's nothing else that would be a culprit.
Old Oct 6, 2004 | 10:08 PM
Car: 88 Camaro
Engine: 305 TBI
im talking to the previous owner right now, he did in fact cut some wires in order to add some subs to the factory system
Old Oct 6, 2004 | 10:12 PM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
sounds like it, basically order yourself some new stinger HPM twisted pair 12ga speaker wire, and run all new speaker wire. hehe.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
