noobie question inside!
Old Nov 5, 2004 | 05:02 PM
85_ZED28's Avatar
Car: '85 Z28
hey guys, starting to plan building my first sub box, thought of a stupid question: When carpeting the box, how do you get the carpet edge so clean around sub? Does the sub cover a little bit of carpet for a perfect look or is it just a very nice cut job?
thanks!
Old Nov 5, 2004 | 05:04 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Sub covers part of the carpet.
Old Nov 5, 2004 | 05:10 PM
85_ZED28's Avatar
Car: '85 Z28
thats what i was thinking, but wouldnt that cause a bad seal?
Old Nov 5, 2004 | 05:45 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Normally the sub coveres the carpet, but you can trace around it with a knife if you're really careful. Otherwise, just make sure the actual hole is as tight around the lip as you can get it, and calk it. That's what I did, sounds awesome.
Old Nov 5, 2004 | 06:44 PM
85_ZED28's Avatar
Car: '85 Z28
so you calk over the carpet?
Old Nov 5, 2004 | 07:52 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I'm pretty sure that 305q was talking about cutting the hole in the box so that the sub will just fit and then running a bead around the lip of the hole to seal the metal cone support structure to the box. Sealing against the carpet wouldn't make sense since the carpet will still allow air to move.
Old Nov 5, 2004 | 08:13 PM
85_ZED28's Avatar
Car: '85 Z28
ya i know, thats what i'm talking about. how can do you cover the carpet with the sub and calk the sub to the board at the same time?
sorry, i wish i knew how to more clearly word my question
Old Nov 5, 2004 | 09:28 PM
305q_ta86's Avatar
Transmission: 5 spd
Yup.
You can either run a bead around the very lip and then put the sub in, or you can do waht I did, which was to mount the sub to the board and then calk it from the inside, and then wire it up and THEN close the box and finish it off.
Old Nov 5, 2004 | 09:38 PM
305q_ta86's Avatar
Transmission: 5 spd
I'd take the box apart so I could show you the inside, but theftproofing being a hassle to get past + lazy = you get the general idea with an outside shot lol.
I even did the exact same thing in my other bird, but there's no grill, and the carpet matches worse lol. Oh, and on that one, the amp is mounted on the TOP lol.
Old Nov 6, 2004 | 06:42 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
just an idea i've heard of and seen used a few times... cover the entire box and then where the holes are for the subs, cut a big X in the middle and trim off most but not all... leave around an inch or so of carpet and place the sub in there, the jobs i have seen look very good! its not to tough to do just kind of hard to explain.
Old Nov 8, 2004 | 07:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The carpet will compress and provide an air-tight seal... much better than just mounting the sub directly to the wood.
Old Nov 8, 2004 | 01:01 PM
85_ZED28's Avatar
Car: '85 Z28
great thanks for the replies everyone
Old Nov 9, 2004 | 12:10 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i usually trace the sub, cut away the carpet underneath, and use weatherstripping. it compresses well and is air-tight.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
