Original wiring rear loudspeakers?
Car: Camaro Z28
Engine: LG4
Transmission: 700
Hey.
Does the Z28 1886 have original wiring to the rear speakers? How should they be mounted?
Just wonderring before i take out the carpet...
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Are you trying to ask whether or not wire was run to the rear speakers? If so, the answer is yes since they would need power to work :lala:
You will be able to tell if it's stock by pulling the sail panels and looking at the wire. Odds are that if it has one big molex connector on the end that plugs into the speaker it's stock since most aftermarket wire is attached/soldered to each speaker post individually.
I'm not sure where the wire was run, but you shouldn't have any problems with pulling your carpet because of them.
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
OK--So, to put in aftermarket speakers I cut off the factory connectors and splice in something that fits the new speakers--no?
The original speakers (rear) are mounted in metal plates--the speaker holes seem much larger than the speakers the factory installed and the speaker wires seem adequate guage to handle speakers big enough to fill those holes if I take out the metal plates, like those factory metal plates are some sort of adapter to fit smaller speakers.
Can I take out those metal plates the speakers are mounted in and put in something more appropriate? I'm doing my whole interior--roll bar, carpet, door panels, seats--traditional hot rod style by an old hot rod shop but want to keep it simple--thanks.
Car: 89 IROC-Z
Engine: 355 TPI
Don't cut and splice. Get a harness for your car and wire the after market HU to that, then that will plug right into the harness in your car. Makes it easier and cleaner. You can get them at Best But, Wal Mart, circuit city, Most auto parts stores, and other places......
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Car: '82 Camaro
Transmission: wc T5
Saigon Bob--yeah, it doesn't make a lot of sense now that I read it. I was basically wondering what speakers will fit in those holes and since then I've done a lot of reading and figured out what I can and can't do--no sweat. GI can do, no sweat--you dee dee Saigon souvenir bookoo--you bik? Vietnam #1!
hectre13
Dec 11, 2023 08:14 AM
colton_carlson
Mar 8, 2019 12:21 PM
