better antenna
Old Jan 15, 2005 | 01:34 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
better antenna
Ok, i get some pretty shotty FM reception around town, and the range on my car is rediculas. (i get even a little outta town and its impossible to get a clear station). Anyone know of any ways to boost the recieving power of my antenna? or is t here something else that needs up grading. let me know, thanks.
-chuck
Old Jan 21, 2005 | 07:21 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
bump...
Old Jan 21, 2005 | 11:20 PM
Trans It's Avatar
Unless you haven't done it already, I'd start by making sure the mast is tight and well grounded with the fender (assuming you have a fender mounted antenna). Also check to see if your antenna cable is securely fastened into the back of your radio unit and is getting a clean connection.
Old Jan 22, 2005 | 04:45 PM
Kandied91z's Avatar
try a radio in your house or a portable radio where you take your car and match reception... if your that far in the woods you're bound to have issues but if it is a problem with the ground or your vehicles antenna then you'll know and there are several things you can do to boost the signal.
Old Jan 22, 2005 | 08:44 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
your antenna probably isnt grounding. prob time for a replacement.
Old Feb 11, 2005 | 12:20 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
what if you have a clear station but your antenna just doesnt move ?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
scottmoyer
Sep 7, 2015 07:06 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
