8" in doors
Old Jan 22, 2005 | 04:52 PM
Kandied91z's Avatar
8" in doors
anyone have an 8" for midbass in their doors?
Old Jan 22, 2005 | 11:23 PM
crazycamaro83's Avatar
i have 6.5 in my doors and when i did it i just had to bearly cut the door and thats just to get 3 screws in because behind the door panel there is a huge hole to fit speakers. oh yeah i have non power doors.
Old Jan 23, 2005 | 12:29 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
i made custum boxes for my door that houses a 6 in 3 in and a tweat doing this is much better then cutting the door panal
Old Jan 23, 2005 | 02:16 PM
Kandied91z's Avatar
yes i too will be making custom pannels as i don't want to cut the doors up. just curious if it has been done on here as i couldn't find any pictures.
Old Jan 23, 2005 | 05:03 PM
guys you dont have to "cut up" the door. i cut about 1/2 in small strip for my speakers to fit no biggy.
Old Jan 23, 2005 | 11:51 PM
Kandied91z's Avatar
any pictures of the finished job? pioneer just came out with their new larger subs with shallow mounting depths. i've thought about looking into those but i don't want to sacrifice clarity.
Old Feb 5, 2005 | 10:14 AM
pskel350's Avatar
i thought about doing this, but i ended up going with a 5 1/2 and a small tweeter in each door. the main reason is that the doors were already heavy as hell, and heavier subs in the doors had me scared as my doors are already starting to sag. how much do the new pioneer subs weigh Jeff? my new door panels with the speakers mounted only weigh about 7lbs, and kept the speakers as close to the hinges as i could.
crazycamaro83 are you having any trouble with your doors sagging?
Old Feb 5, 2005 | 09:18 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
my doors already have worn the rocker panel from saggin.. you can fix that by readjusting them... but yea the extra weight will make the door sag faster i think
Old Feb 8, 2005 | 01:22 AM
Kandied91z's Avatar
have no idea what they weight. it depends on the purpose though. the 8" are for midbass and aren't heavy at all. now the 6.5 components i would not put in the doors. they are for the more solid areas in the car.
you'll have to hear this setup when it's finished. i never noticed how bland the car was with the standard 4x6's and 6x9 setup. removed them and put a few speakers in the right area.
wow...
Old Feb 8, 2005 | 09:37 AM
pskel350's Avatar
wow...
so i should of not put those in the doors, thats not good since the panels are already made and getting upholsterd (sp?)
im not looking for all out sounds, just a nice sound that i've never had in the car from day 1. if mine sounds like crap, then you'll have to tell me where to put them the 2nd time around lol
Old Feb 8, 2005 | 11:15 AM
6.5 in doors
alpine type r 6.5
Attached Thumbnails 8" in doors-c-documents-settings-dionysus1
Old Feb 8, 2005 | 11:17 AM
6.5 in doors
farther back
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
