4 channel amps
4 channel amps
i have a 4 channel amps that im putting in the car. how do i wire this? do i put channel 1&2 in the back speakers together, or on one side of the car?
this amp for the component speakers is totally seperate from the sub's amp right?
Car: 92' B4C Camaro
Transmission: G-Force T5
If you are using this Amp only for the components, then YES it's seperate from the Sub Amp. As for putting which channel to which speaker, I normally put Ch.1 to L. Front, Ch.2 to R. Front, Ch.3 to L. Rear, Ch.4 to R. Rear. Hope this helps
Car: 92' B4C Camaro
No you don't have to change it, the way I showed I normally do it is just my preference. The way you are doing the wiring is fine.
raymondandretti
Sep 27, 2015 06:43 PM
