Low volume when cold outside
Old Mar 7, 2005 | 11:35 AM
3rdgenstm's Avatar
Car: ‘92 Z28
I don't drive my car very often in the mornings, but a few weeks ago I ventured out early on a 35 degree Saturday morning. The volume on the radio was low, even when I turned it up. I thought it may have been a abd connection with the faceplate. So I took it off and reattached it and had no improvement. When the car warmed up after 15-20 minutes, the volume came up to where it should be. It sounds as if the rear speakers are 'off' and the fronts are the ones that are on, but only at minimal volume.
It is a Pioneer 3600 with Pioneer 6x9 and 4x6 speakers.
My dad has the same radio in his Vette (but with Infiniti speakers) and said he left his car out the other nite and got in the next morning, he had the same problem. So I don't think it is just my unit (or the speakers).
Does the unit just need to warm up? If so why and what can I do to prevent it from 'freezing'? I have only had one other aftermarket radio in a car before, so I am not real up to speed on this.
Thanks.
Old Mar 21, 2005 | 03:15 PM
jojo22's Avatar
Car: 91 firebird
Engine: undecided thinking 383 stroker
Transmission: ??????????
yes electircal systems need to warm up to work properly
Old Mar 21, 2005 | 03:30 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
It should only take 5 seconds for all the outputs to work on that thing. Take it back, it needs to be fixed. BUT, let the service provider know it only happens when it’s vary cold.
Old Mar 21, 2005 | 04:20 PM
Mr.W's Avatar
Car: 91 RS
Engine: 305 TBI
Transmission: Stock auto
I have the pioneer 4600 and I had that problem twice this winter.
Old Mar 21, 2005 | 08:33 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
i noticed that the cds that come outa my p6600 are hot enuff to burn you if you listen to it for a long time..... is that bad?
Old Mar 21, 2005 | 11:49 PM
jojo22's Avatar
Car: 91 firebird
would probably indicate that you have a lot of wires and stuff blocking the vents in the hu i would try to clear that up cause its never good
Old Mar 22, 2005 | 06:19 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Could be.
The thing to do in this case is to pull the HU out and use a DMM to check the resistance of the loads (speakers). Each one, and make sure they're all at 4 ohms. You my see a little less then 4 ohms, but not much. If all good there, it's normal. The amp IC and power supply will get hot. How hot is subjective. Check the loads, if there good it's normal.
Old Mar 22, 2005 | 03:14 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yea i kno the loads are good.. and its only really hot if ive been drivin around and the trans has thrown heat onto teh cdplayer..... its never enuff to cinge but is uncomfotrable
Old Mar 22, 2005 | 04:38 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I almost burned my flesh off when I touched my 8600... damn that thing is hot...
*** bless 4 year replacement plans... (with no questions asked, of course)
db057
Apr 28, 2019 07:45 AM
Jk_Under
Sep 8, 2015 08:13 AM
dimented24x7
Sep 6, 2015 03:51 PM
BOOT77
Sep 5, 2015 03:55 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
