Grounding Amp & Stereo Chassis together?
Car: 89 Camaro RS
Engine: 305 TBI
Ok, as the topic is.. Is it at all worth while Grounding Amp & Stereo Chassis together? The RCA's I have, also have a wire running up the middle with it. generally used as a ground between two audio devices. So is there any advantage grounding the cases of the headunit and the sub amp together? Or should I just use the wire as the remote turn on.. I doubt the power running though it for that would cause any 'noise'..
I ran the RCA wires right up the middle of the car.. worked out quite well.. since I'm running the power wires down the passenger side.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Ground is a ground if you ask me. I would just go to the closest clean grounding point you can find. I ran my remote on line inside the same plastic wiring conduct as my RCAs without any problems.
Car: 89 IROC-Z
Engine: 355 TPI
Re: Grounding Amp & Stereo Chassis together?
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
