Does this radio fit my car?
Old Jun 6, 2005 | 09:33 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi..
Does this unit work with my steering wheel controls ??
http://cgi.ebay.com/ws/eBayISAPI.dll...779399233&rd=1
/N.
Old Jun 6, 2005 | 11:25 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Should slide right in and fit fine.
Old Jun 6, 2005 | 12:25 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Can I use the controls in the steering wheel?
/N.
Old Jun 6, 2005 | 12:30 PM
vernw's Avatar
Most likely, but have them take a picture of the back of it and comnpare it to your current one. Want to make sure the harness connectors are the same to be able to use the S-W controls. Since it's the same year if I remember right, shouldn't be a problem - but I'd check to make sure.
Another option is to talk to a dealer - get the part numbers for the radio for both cars and see if they're the same.
Old Jun 6, 2005 | 12:44 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
The connectors looks the same but the part nbr is diffrent........
/N.
Old Jun 6, 2005 | 07:38 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
of course the part numbers are different. That radio never came in F-bodys. What you really need to check and see is if all the pinouts are the same. Find a wiring diagram for both models and compare. But given GM's recycling of parts, I'm sure if it looks like it will work, it probably will.
Old Jun 6, 2005 | 10:49 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If you’re in Sweden, that could be a problem with tuning.
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
