Bose question
Old Jun 9, 2005 | 09:41 AM
Mr. Brett's Avatar
Car: 1989 Camaro IROC-Z
Engine: 5.7 TPI
Bose question
Quick question- I installed an aftermarket deck in my '89 Camaro yesterday. It originally had a Bose tape deck. After wiring everything up the radio works fine but I get no sound from the speakers when I switch it to CD. I tried a different deck with the same results. I consulted my local car audio shop and they said I shouldn't need any kind of adapter. Are they wrong?
Old Jun 10, 2005 | 09:58 AM
Mr. Brett's Avatar
Engine: 5.7 TPI
Anybody? I've done a search and can't find a clear answer to my problem. Any help is very much appreciated.
Old Jun 10, 2005 | 02:39 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
I think i know whats up with your install. Im not sure but im thinking that bose put a amp with your speakers and you forgot to hook up the remote turn on wire. it is usally the blue wire on the deck. thats what happend to me when i hooked up my dad's cd player in his ford explorer.
Old Jun 10, 2005 | 02:49 PM
3rd gen V8's Avatar
Well i did some looking and reading on my repair manual and found out that your blue wire should go on a pink wire for your amp relay.
Old Jun 10, 2005 | 04:30 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Works with the radio, but not the CD? Check your stereo manual and see if the wire is a remote power, or an antenna power wire. Might be powering the amps only with the radio, turns off with CD. Be unusual for aftermarket stereo to do this though. And normally you'll need an impedance matching box to work with the Bose system, doesn't usually sound that great.
Old Jun 11, 2005 | 01:25 PM
Mr. Brett's Avatar
Engine: 5.7 TPI
I've had it wired up without any kind of adapter and it sounds fine. Are there some Bose setups that don't use a different impedance? I'm going to try swapping wires to see if it fixes it. Thanks guys!
Old Jun 13, 2005 | 12:12 PM
Mr. Brett's Avatar
Engine: 5.7 TPI
Swapped a couple of wires and it works like a champ. Thanks guys!
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
