need help with system
Old Jun 15, 2005 | 06:04 PM
woody88's Avatar
Car: 91
Engine: 3.1 v-6
i have 2 jl w6 12's in my camaro with a old school power 300 rockfordfosgate hooked to them and i have a Q-logic box to fit in the whole in the back and i dont think that i am gettin all that i can out of them should i build a box all the way across in the trunk/hatch, and i have a old school power 150 to should i hook that up to them to.
Old Jun 15, 2005 | 06:18 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
For starters what impedance (ohms) are the subs running at?
Second, You should save your pennies and buy 2 matching amps... around 500w each. get yourself and optima red/yellow top battery, and a distribution block. Dont run anything less then 4 gauge wire to the back.
Heres what the back seat of my camaro looked like:
I had built a custom box with 1.5 cubic feet of air space in each side, had 2 12" JL W6's. In the back seat (the pic below) I have 2 500.2 amps with a punch link to make it appear as one, 4 1.0 farad caps, and a fuse/dist. block in between them. I was running 2 gauge wire to the back on a 100amp fuse and had a 150 amp alternator and optima red top battery.
-Jim
Old Jun 15, 2005 | 09:20 PM
jimp2001's Avatar
Engine: LO3 305 TBI
forgot to attach image, lol
Old Jun 15, 2005 | 11:21 PM
traksta15's Avatar
Car: on the hunt for a 3rd gen again
i wouldn't use caps....also you don't need 2 amps, u can just run 1 bigger one (it doesn't matter) there's box plans around here somewhere floatin around for the dip area........
Old Jun 16, 2005 | 02:41 AM
semiller26's Avatar
Car: 1986 Trans Am
whats up with all this don't use caps stuff? they definetly make a difference. especially since car audio amps use POS switching power supplies. the power supply is the most inportant part of the amp. A stiff power supply will allow the amp to perform its best. It will allow the amp to supply greater current to the output transistors. Besides bass is harder to reproduce because it is a slower wave than the rest of the audio spectrum.
Caps are a good idea.
Old Jun 16, 2005 | 05:11 PM
jimp2001's Avatar
Engine: LO3 305 TBI
most JL subs run at 3 ohm, if you use 1 amp, and crank it up enough, it will overheat and potentilly destroy the amp. most amp manufaturers can detect the cause of the problem and won't warranty it because it was wired improperly.
If the subs are running at 3 ohm, which i assume they are, you need to get an 2 amps that can handle a 2 ohm mono load, or purchase 1 larger amp with another 12" sub and wire the sub box to a 4 ohm mono.
If you dont understand how to wire DVC subs, or need help, feel free to IM me
Old Jun 16, 2005 | 09:39 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
3 ohms? never heard of a jl sub running 3 ohms.
On my jl's there was no option to run them at 3 on the manuel for them.
Old Jun 16, 2005 | 11:03 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I read that a few times and I'm still scratching my head..
Old Jun 17, 2005 | 11:18 AM
jimp2001's Avatar
Engine: LO3 305 TBI
the make differnt ohm ratings on different subs. the reason for a 3 ohm rating was to allow a triple sub box to be mono'ed out to one amp. a lot of people that bought JL subs never realized a difference and bought dual 3 ohm subs thinking they were 2 ohm
Old Jun 17, 2005 | 04:28 PM
9177's Avatar
I know for sure they did it on the W7 line. According to JL it was because a 3 ohm coil was due to sound quality (except the 13w7 which has dual 1.5) To me it looks more like a marketing thing. This gives you more of a reason to buy JL audio amps as the put out the same power @ 1.5-4 ohms.
Old Jun 17, 2005 | 04:37 PM
jimp2001's Avatar
Engine: LO3 305 TBI
i had 4 12" W6 subs running at 3 ohms
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
