how to make the hatch look pretty.
Old Jul 21, 2005 | 02:05 AM
357transam's Avatar
Car: 1986 T/A
Engine: 350 bored .040, s/r torquer heads
Transmission: 700r4, tci shift kit
Axle/Gears: stock borg warner
Hey guys... i need some help. I am using two infinity basslinks right now, and
Old Jul 21, 2005 | 02:12 AM
357transam's Avatar
Car: 1986 T/A
OOOPS! sorry about that guys. computer went on the fritz.
Anyway, i have two infinity basslinks, and an alpine amp. The problem that i am having is that i am having a hard time making it look pretty. right now i just have the amp mounted on the rear deck and the subs nestled on each side of the hump in the rear that covers the hatch lock motor. since they are the full enclosure with the amp inside i dont need to build a box. but i do need ideas with how to make it all look good. IDEAS PLEASE!!!
Old Jul 21, 2005 | 08:12 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Two things: When you say that you mounted the amp to the top of the hump, how did you do it? If you used screws, realize that the gas tank resides directly under the hump. Most people use Velcro if they're going to have their amp(s) sitting there. I stuck a piece of 3/4" mdf under my carpet and screwed through the carpet into the wood.
I'm not sure what you can do to make the bass links look better aside from fabing some kind of cover.
Old Jul 21, 2005 | 10:38 PM
traksta15's Avatar
Car: on the hunt for a 3rd gen again
got any pics of the current install??it'll help us out some..........
Old Jul 21, 2005 | 11:06 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
hey, they don't call 'em FIREbirds for no reason!
Old Jul 22, 2005 | 01:18 AM
357transam's Avatar
Car: 1986 T/A
Heh, yeah i did think of the whole gas tank thing, so i got some velcro just like everybody else. im not sure how to attach the pictures without using the attach file thing at the bottom here (they are too big for that) so ill just have to make you look at my site. im going to put them up right after i post this so hopefully they will be there by the time you guys look at this. the site is www.cardomain.com/id/357transam should be like the fourth page...
Old Jul 24, 2005 | 10:37 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
how close is our gas tank to the metal of the hump.??
Old Jul 25, 2005 | 02:22 AM
357transam's Avatar
Car: 1986 T/A
uhhh... i dont really know, i havent ever checked. I dont want to drill through the hump though. i would rather do something that wouldn't be permanent.
Old Jul 25, 2005 | 08:25 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
3/4" or closer. Even if you use 1/2" screws, do you really want a couple of sharp pointy objects sitting 1/4" away from your gas tank? Get rear-ended, go boom.
Velcro holds to factory carpet VERY well.
Old Jul 25, 2005 | 10:38 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
well my amp is like on the top part of the trunk. and its maybe 1/2 inch screws the biggest that i used. is this still a problem?
Old Jul 25, 2005 | 10:54 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
by"top part of the trunk" do u mean the top of the hump? if so, i think that is where the tank is, i might want to replace the screws with some velcro..
Old Jul 25, 2005 | 11:55 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
nvm i just took them out. it aint gonna move anywhere. i checked it so its all good.
Old Jul 25, 2005 | 12:23 PM
Jim85IROC's Avatar
Read what I just wrote.
Old Jul 25, 2005 | 12:48 PM
357transam's Avatar
Car: 1986 T/A
Ok so what about mounting the amp in between the subs with something? Like cutting some wood to fit between the subs, and covering it with something, then putting the amp there? I know that amps only work to their full potential when they have sufficient airflow to cool them down, so would the amp recieve less cool air between the subs? Also, the subs have dual cones (one through the top, one on the bottom). If i mounted the amp in between them, would it block some of the sound out?
Old Jul 25, 2005 | 03:29 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
I highly doubt it. But it looks pretty nice already. at least the wires are covered and under the carpet and everything. It looks like you took your time. Congrads
Street Lethal
Apr 30, 2019 12:14 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
