Will this blow the subs?
Old Aug 4, 2005 | 12:05 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
I just put this setup in my buddies camaro and he is scared to crank it up because he is afraid something will blow. It is possible to wreck the subs with this? We got a enclosed box with 2 12 inch SPL 1800 watt subs powered by a Sony Xplode 1000 watt amp and a pioneer headunit. It pounds pretty damn hard too. What do you think, easy to blow them or not really? Thanks again
Old Aug 4, 2005 | 12:08 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
xplode 1000 watt amp, if it's the same one we sell, is only 2 x 165watts rms
Old Aug 4, 2005 | 12:12 AM
Engine: 2.8 Lt
Transmission: 5 Spd
Might be. Says 1000 watts on the back. Sony Xplode. It hits very loud though Just wondering if it will blow the subs.
Old Aug 4, 2005 | 05:53 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
you need to get more info. that sony amp is only pushing like he said 165x2 I had it before. Check the RMS rating on your subs. Its always good to match them.
Old Aug 4, 2005 | 07:23 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
What will damage a sub is distortion. And you can get distortion by cranking anything to high.
Old Aug 4, 2005 | 10:53 AM
Engine: 2.8 Lt
Transmission: 5 Spd
I'm new to the whole world of subs and amps. I will get more info for you. Not sure what u mean by distoration? What is it? lol Thanks
Old Aug 4, 2005 | 06:22 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
what he is saying is if you crank the volume and you are hearing the subs crackle and snap rather then nice solid clean bass then you are damaging the subs. That 1000watt xplode won't hurt the subs however if you do crank it up the amp might start throwing some pretty dirty power to the subs causing them to prematurely wear out.
Old Aug 4, 2005 | 10:27 PM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
shouldnt blow the subs... and i dont think that sony amp will hit 1000 watts either... check the amp rating on the fuse..... amps x volts = power in watts... that'll give you the max power it'll hit..... but like they said... just dont turn it up to loud to the point where it sounds distorted...
Old Aug 9, 2005 | 08:49 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
This is the perfect combo to blow subs, but it also requires a semi-retarded user in addition to the right equipment for that to happen.
When you take a low powered piece of crap amp like that sony, then expect miracles from it, you can overdrive it and cook your subs. Because it's hard to hear distortion at those low frequencies, by the time your subs actually start to sound bad, you're pumping MAJOR distortion into those subs, which is what will blow them up.
Basically, you need to listen carefully. Once you overdrive the amp, you'll hear that the subs start to sound fuzzy and unclean, and turning it up louder just makes it fuzzier instead of louder. The key is to keep it below that level.
Most people who blow subs do it because they just keep turning it up into that distorted region because they think they're making it louder.
Old Aug 9, 2005 | 05:57 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
I have found Sony amps have high distortion,
personnaly I would spend the same money on a higher quality amp with less power
Old Aug 10, 2005 | 09:53 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
What if you get distortion because your brain is shaking around and you can't see/think/hear right... even moreso if you turn up the volume?
What is that kind of distortion called? Am I clipping my brainwaves?
Mmmm, reminds me of that drug commercial with the eggs vs. brain... "This is your brain on drugs."
/why? -- you'll never find out
Old Aug 10, 2005 | 10:33 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I think your starting to affect more then how things sound, STOP shaking you head like that.
Old Aug 10, 2005 | 10:47 AM
ScrapMaker's Avatar
sorry, it's the bumpy-*** suspension of the car.... my brain can't take it anymore...
seriously though, if the windows are nearly all the way up, just enough to let air flow by your ears... it's really loud and you basically just hear distortion... but maybe it's just me...
I know it's not real distortion, because I can roll the windows down, or open the hatch at the same volume and it's just pure, delicious bass coming from the woofers.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Fanatic1074
Oct 2, 2015 03:47 PM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
