Factory Performance Sound System
Old Aug 5, 2005 | 05:13 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
While working on replacing my headliner, I thought I would replace the speakers in my sail panels. The problem is that whenever I turn on the bass enhancer or factory sub, iot sounds like blown speakers. Once I pulled everything apart, the speakers were in good shape.
Can anyone tell what is causing the problem?
Any advice on what to replace the speakers with?
If I replace with one set of speakers, which wires do I use?
www.geocities.com/dzperf
Old Aug 6, 2005 | 11:36 PM
daytonata1983's Avatar
Car: 1983 Daytona Trans AM Pace Car
Engine: 305 Cross-fire
your amp is toast theres a factory amp for the performance sound system it sounds to me that thats your problem
Old Aug 10, 2005 | 10:36 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I wonder what the specs are of an amp like this?
does the amp only power the 'subs'? or other speakers as well?
I know the headunit still has an amplifier in it as well.
you could go the different route, and actually keep 4x6s and 6"s in the sails, just replace them with new, high-quality versions...
everyone pulls them out and puts 6x9s or just components.
Old Aug 10, 2005 | 11:00 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
I tried hooking 6 1/4" Boston Acoustics to the sub side but as mentioned earlier, they still sound totally distorted.
I'm going the easy route and using BA's in the dash and sail panels and will install a single sub in the well. Just looking for a little more than the factory sound system.
Old Aug 10, 2005 | 12:34 PM
ScrapMaker's Avatar
I think it would kick *** to get some good 4x6 plates, and some sort of 6" subwoofer/mid-bass driver and put it in the stock location
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
gta90
Sep 15, 2015 04:00 PM
midias
Aug 22, 2015 01:42 AM
novaderrik
Aug 10, 2015 12:44 PM
