1988 GTA Rear Speaker Size
Car: 1988 Pontiac GTA
Transmission: 4 spd automatic
I am sure this is an easy one for most of you. What size speakers can be mounted by the side panel rear seat location? I am not sure whether to buy some 6 x 9s with bass filters (will be running a separate bass tube) or get a 5 1/4 or 6 1/2 component system. I do no want any speaker grills to show. Any help would be appreciated!
Thanks!
Jeff
Thanks!
Jeff
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
if it is a GTA it should have the Performance sound system in it which has two speakers ( 5 1/4 & 4x6 ) i personally am looking for this set up...
Car: 2000 Trans Am WS6 (Black)
Didn't some GTAs come with the bose setup instead? or was that just camaros?
anyways, a lot of GTAs have a separate amplifier for miniature subs in the sailpanels...
I really want this setup too, to get some good midbass in our cars! 6x9s just can't do it, because they rattle everything... those stock 'subs' have tubing/porting to help them create bass, without the rattles.
i was surprised when i finally pulled the set up out of a formy... i didnt kno they knew that much about sub enclosures and stuff before i pulled one of those speakers out, cool. and all cars with performance audio have seperate amps for those 5 1/4 speaks acompanied with a gain switch to the right of the sterin column, but when i finally get the right set up for an 89+ (not sure if 87-88 set ups have same connectors) i will put that switch were the fog light switch should be, since i just have an ugly *** plate to remind me that my car is not well optioned...
ya the switch works the single amp for the 5ers... i dont kno what would happen if the amp didnt work anymore, youd either have to get another one or go aftermarket, because that thing is pretty small, and there are no markings to tell you what the wires are... its located under the map pocket on the passenger side btw.
well, you hafta take off that plastic panel below the map pocket, and then you will see the bottom part of the amp and its bracket. our computers are under that black plastic piece
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
