1100 watt sterio what size alt.
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
hey i have a 1100 watt amp and i need a altinator to keep my battary goin and was wondering what amperage of a alt. i need to keep my battary healthy? not to worry if it does die though i have a 9 year free no questions asked replacement plan!
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I have a 1400 watt amp (75 X 4 and 1100 X 1 for 5 channels) in my system and do just fine with the stock 105 amp alternator. I also charge 2 batteries (1 for car, 1 for system) with the same alternator using a battery isolator.
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i have a 1400x1 @ 1 ohm amp, sucks a lot of juice running 1 ohm. before, i had a kenwood 35x4 for my highs and those 2 amps pulled enough juice to actually buck the car, drop the rpms like 1000 revs when the bass would hit. i put in an excessive amperage 200 amp alt and an optima 31 series yellow top, 1/0 gauge wire for all my underhood wiring and back to the amps and it took care of it. only complaint is the idle performance isnt the best so i turn my stereo down when i stop so i dont stress the amps running them at low voltage. im also running a 200x4 orion amp now, but its turned down most of the way until i get my components in.
i could turn the idle up to 800 or 850 or so but i like the lopey idle at 600, im not sure if it can be modded to turn on earlier, but i know large case alternators start charging at a lower rpm.
Pac J
May 17, 2020 10:44 AM
raymondandretti
Sep 27, 2015 06:43 PM
