Daisy-chaining RCA's on amps
Old Sep 29, 2005 | 07:22 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
If I run my RCA from head unit to my subwoofer amp and use its built in low pass filter, then will it output the original signal or will output just the low freq's through the RCA out that would go to my next amp.
Old Sep 29, 2005 | 09:55 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Should pass everything. What's the make and model?
Old Sep 30, 2005 | 05:33 AM
MattODoom's Avatar
Car: '88 G T/A
Its a Directed Audio 350d.
Old Sep 30, 2005 | 06:02 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Should pass everything. The only amp I've seen that didn't was some total POS flee market junk.
Old Sep 30, 2005 | 09:07 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
It should pass everything, I had mine set-up that way w/ my old HU (because it only had one pre-amp) and it worked fine.
Old Sep 30, 2005 | 11:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Im yet to see an amp without a straight through output on it. On my setup i have 3 amps daisy chained and all different brands too
(yes i do have a ghetto setup but it works for me)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
