where can i get a wiring diagram for a sony headunit?
Old Oct 23, 2005 | 02:54 PM
91NiteRida''s Avatar
Car: 1991 Camaro
does anyone know where i can get a wiring diagram for a sony cdx m3d1 without paying sony for another diagram?
Old Oct 24, 2005 | 08:10 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Why do you need it? Sony radios follow the standard wire color convention that all aftermarket radios follow.
If you are putting one into your car, you should be using a wiring harness adapter instead of hacking up your car to save $5, and if you are using one of those, all of the wire colors will be a match for the sony wires, so the installation will be a snap. If you already hacked up your car (or if the previous owner did it for you), then you can just use the standard wire colors.
If I can ever get my piece of crap computer to stop crashing when it loads .pdf files, I'll find something that's got the standard wire color info, but until then, poke around www.installdr.com until you find it.
Old Oct 24, 2005 | 01:16 PM
Jim85IROC's Avatar
http://www.installdr.com/Harnesses/GM-Wiring.pdf
Pay particular attention to the column titled "Typical New Radio Equivalent Wire Color".
Old Oct 25, 2005 | 12:34 PM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
good thing i saw this, not only are my factory wires cut, my headunit wires are too. total pain in the ***. I bought the metra connector before i saw that.
Old Oct 25, 2005 | 07:24 PM
Car: 1991 Camaro
Thanks for all the help...Im not sure if my question made any sense but i know which wire is which on the factory harness,i just dont know which wire is which on the headunit...Most of the time,there is a sticker on the actual headunit that states which wire is which... But i guess i was wrong
Old Oct 26, 2005 | 07:19 AM
Jim85IROC's Avatar
Your question made perfect sense, and my reply gave you all the information you need to solve your problem.
Old Nov 10, 2005 | 11:13 PM
UCF1Slider's Avatar
Car: '89 RS Vert
Engine: LO3
Yellow = 12v constant
Red = Ignition
Black = Ground
White = (Left?) Front +
White w/black stripe = (Left?) Front -
Gray = (Right?) Front +
Gray w/black stripe = (Right?) Front -
Green = (Left?) Rear +
Green w/black stripe = (Left?) Rear -
Purple = (Right?) Rear +
Purple w/black stripe = (Right?) Rear -
Orange = Illumination (DO NOT ATTACH THIS WIRE)
Blue = Power Antenna (only attach if you have a power antenna)
Blue w/white stripe = Remote wire (don't need this unless you want to hook-up an amp remote wire here)
The reason I put (Left?) and (Right?) is because I can't remember which color is which side... I know gray and white are for the front speakers and green and purple are for the back and the + and - are all correct.
If you need the colors for the factory wiring you should go to 12volt.com and find their wiring guide and put in the info for your car.
89GTAOz
May 16, 2020 09:31 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
