Stereo won't fit all the way.
Old Aug 7, 2015 | 09:51 PM
mustangman65_79's Avatar
Car: 1989 Iroc
So a while ago I installed a sony deck, using the correct aftermarket plate. The problem is, the deck will not go all the way down. It sticks out about 3/4 of an inch.
It seems to hit the floor on the other side. Is there anything that can be done?
Old Aug 8, 2015 | 11:35 AM
cdoyle's Avatar
Re: Stereo won't fit all the way.
Could you post a pic of it installed now?
I'm trying to remember if there is anything back there that it could be hitting.
The stock stereo slide into a bracket, but I don't think you need to remove it.
Old Aug 8, 2015 | 12:05 PM
Car: 1989 Iroc
Had to bend the stock bracket out of my way, as it made it sit even higher. I can try to get a pic soon.
Old Aug 8, 2015 | 01:00 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
IIRC, this is pretty common and you often see the head unit sticking out a bit on a lot of installs. On mine it was hitting the HVAC duct. If you are inclined to do so, you could modify the duct to allow it to fit flush with the face plate.
Old Sep 30, 2015 | 04:32 PM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
When I put my Kenwood in, I had to cut a piece of some plastic part in the back to get it to go all the way in. I think the cable connectors that plugged onto the back hit it or or the back corner or something like that.
Old Sep 30, 2015 | 07:14 PM
OLDYELLR's Avatar
Car: '85 IROC
There is a bracket back there with a hole to accept the "bullet" on the back of the stock stereo, that supports the rear. You may have to remove that bracket.
Old Sep 30, 2015 | 09:37 PM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Make sure you jam the wiring down so that the radio slides over them. If you have that screw jetting out the back, take it off if it doesn't find a hole. Another thing is, what is the length of the deck? They do come in different sizes, maybe yours is an extra long one?
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
justin57
Aug 20, 2015 07:05 PM
slade5612
Aug 11, 2015 07:19 PM
