custom inexpensive sub box
Old Feb 18, 2006 | 09:41 PM
  #101
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
greatest amount of sealed space using the least amount of interior volume
Old Feb 19, 2006 | 04:40 PM
  #102
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
so you saved a few 0.1's of cubic feet to go this route?
sounds to me like you just had something to prove...
Old Feb 19, 2006 | 05:40 PM
  #103
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
One guy at work has one of the new Mustangs, and in his trunk he has, what one may not expect, two old Kicker amps, one driving his speakers, and one driving his single subwoofer.
The subwoofer runs at 2 Ohm, it's a Rockford Fosgate Punch 2, a little 8 inch, in a pretty small enclosure, and damn does it kick hard.
I guess it's really a lot about design, not size.
Gives me hope *lol* knowing that I can get an old Kicker amp or similar and run two 8" woofers in the backseat area, although I have NO CLUE what so ever as to how I'll mount them, what kind of enclosure I'll make etc etc NO CLUE
Old Feb 19, 2006 | 10:06 PM
  #104
jamon8's Avatar
Engine: 350 tpi
I was going with a plate all along, even when I told you I wasnt to get you off my back.
I do have to thank you though! without you telling me how to not do it I could have never formulated the plan to do it right.
I am not doing this because I want to prove you wrong. I am doing it so those of us who think the well of our cars can be used to create massive bass using minimum space and minimum dollars.
The only part that took any time to do was setting up my fan so that I could get the undercoating and the fiberglass to dry overnight.
I have 2 Visonik 10 inch 250 watt rms subs driven by a power acustic amp. apline 6x9's and Jbl 4x6's with a kenwood 425 headunit.
I spent just over 500 dollars not including the isolated dual battery setup. that includes the wires materials and everything.
Any questions please pm me
Old Feb 19, 2006 | 11:13 PM
  #105
ScrapMaker's Avatar
fyi, a 4'x8' peice of MDF is roughly $8... I bet that's cheaper than all the fiberglass and labor you went through...
hey but at least you can be different. That's all that matters, right?
and no you didn't prove anyone wrong... plates are not ideal for most subs, and of course our wells are good for making bass... you just need a big box and some big subs... our cars will pound like any other... except the rattles will drive most people nuts.
I'm always amazed at how far some people will go to be different... but that's what makes life interesting... doesn't really matter if it's easier, cheaper, or more efficient to go the standard route... it's the fact you tried something that others won't.
props.
Old Feb 20, 2006 | 12:28 AM
  #106
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Assuming you're using 3/4" MDF that's another 1.5" of width and depth. It doesn't seem like much but it really starts to add up with larger boxes and boxes. Also, his method will maximize volume a lot better than MDF will. His box conforms to all the well’s curves and doesn’t waste space available in the rounded parts of the well. As we all know, there are no real edges in the well, everything has a curve to it. That's also giving him more volume.
Cost me $20 last time I got a sheet from home depot. current lowes price - when I made that link the price was $21.88 for a 3/4" x 4' x 8' sheet.
That will buy you a gallon of resin from US Composites, which would be way overkill for something like this. Also, he might have done it with stuff he had lying around (already purchased so not factored into his price). I've got no idea.
As for time, my crappy excuse for a MDF box took a good 4 or 5 hours to build. I'm guessing there's about that much time in jamon8's box.
(and)
(and)
Sorry scrap, but I've got to side with jamon8 gain. You do sound like an *** saying all this. It’s not like he’s attacking you and saying you’re wrong. If the guy is happy let him be.
I will agree that it's off the beaten path and it's not something I would want to do, but it defiantly got the job done if he really sealed up everything. If the seam between the plastic trim and the carpet is solid glass/bedliner then there's a nice airtight seal back there. If he really sealed up everything then he's not running a plate at all but rather turned the whole well into a box, which is what he has been claiming. Sure, the plastic side is going to flex some but with his two subs it's not going to be that big of a problem IMO.
I wouldn’t do it because of the plastic flex and it just doesn’t seem like the “right” way to do it. I don’t want to trash my interior (carpet and hatch trim) in the name of building a sub box.
Now if he was 'different' in that he cut holes in the bottom of the hatch to mount his subs in with the magnets sticking out of the car to run free air I would be saying it was stupid
Also, I’ve got no rattles to speak of but I wish I could get my rear end quiet. Stupid noisy gears
Old Feb 20, 2006 | 06:58 AM
  #107
jamon8's Avatar
Engine: 350 tpi
4'x8' sheet $22
fiberglass resin jelly $9
gallon rubberized undercoating $11- had in garage but used 1/2
heavy duty liquid nails $4
nuts, bolts, metal braces $8
2x4, wood screws- I had around the garage
Really guys the only reason that I used the plate method is I am going to take this car around the united states, canada mexico and across the pond maybe. space is a key issue to me even if it is .1 cubic feet, although I am sure I have saved more than that.
I took out my rear seat and behind my seat in the foot area I have the amp mounted on some 2x4s and the hump where the front of the bucket was.
in the seat well I have my 2nd battery. I used the set up of the 2001 Aurora with the battery venting system. Now I need to set up my laptop and mount it somehow buy I have not figured that out yet.
also 4-5 hours seems about right but honestly I could not tell you because I did not do it all in one day. I also forgot the cost of the black velvet. looks pretty cool with speakers.
My rear is whining two and I put some synthetic in it and I might drive it untill it die and bring a ring and pinion kit with me or find a used disc brake unit where ever I may roam.
Sorry for bieng so cocky earlier but my system sounded so good for the amount of money I spent .
kenwood head unit 150
jbl 4x6 50
alpine 6x9 65
power accustic amp 110
Visonik 10's 100
sealed plate and material 50-60
Oh yeah bass blockers 10
The bass hits hard and I can hear the symbols very clear and the singer sound like they are right there in the car with me
Old Feb 20, 2006 | 08:32 AM
  #108
ScrapMaker's Avatar
I just don't understand why you keep calling it a 'plate' setup... seems more like a non-removable box to me...
and no offense intended, but the first time I built a box for my car, it took about an hour from design to finish (well, I let it dry for an hour too)... and all I had was a circular saw and a hand saw... I'm no craftsman either....
guess I was just impatient.
"Really guys the only reason that I used the plate method is I am going to take this car around the united states, canada mexico and across the pond maybe. space is a key issue to me even if it is .1 cubic feet, although I am sure I have saved more than that."
Out of curiosity... when you refer to 'space,' are you referring to the space left over for luggage, or are you talking about the extra space you gained for the subs...?
The reason I thought people made plate setups in the first place was so that they could store luggage underneath, effectively leaving their entire well available for storage... I presume you can no longer remove the plate from your fiberglass 'enclosure,' right?
And sorry if I came off like an ***, but it really sounded like you were being cocky, like 'plates' were ***-like or whatnot... what you have, my good man, is not really a plate setup anymore. Glad it works for you... I had an idea like that where you could 'unlatch' the top of the plate/box, and still put stuff inside... it just required some sort of seal/lip to work properly, and was a big hassle, so I gave up.
Old Feb 9, 2007 | 11:07 PM
  #109
SpankAstang92's Avatar
Car: 1992 Camaro
Engine: 305 TBI
I had a plate with 2 10" sony xplodes
Im not saying anyone is right or wrong with this whole plate idea. How ever, i used 3/4" MDF wood, and some foam for windows, (the peel and stick) lol. My neighbor advised me to use 2 10" sony xplodes. To my surprise it sounded awesome.
Old Feb 10, 2007 | 08:56 AM
  #110
ScrapMaker's Avatar
It's just that with more powerful woofers, (and perhaps even the sony's,) once you hit hard, the pressure would most likely be enough to lift the plate... causing it to lose what very little pressure it had in the first place...
now, if you make a 'ported' plate, or just use woofers specifically designed for IB, then you might be set..
Old Feb 12, 2007 | 06:38 PM
  #111
admrlam's Avatar
Originally Posted by jamon8
I went with a plate. but I fiberglassed it in.
1- I used rubberized undercoating inside the well and the bottom of my plate.
2- I made the plate extend to the end of the frame humps.
3- I made a brace in the middle with a 2x4 on the plate, a 2x4 on the bottom of the well(shaved to meet the contour), and two 2x4 braces holding them together.
4- I also used metal angle braces to hold it together better.
5- all that was undercoated using a gallon can of undercoating and some rubber gloves. I also sealed the inside of the box with undercoating and a flashlight.
6- On the bottom 2x4 in the well I used two bolts to secure it to the well.
7- on the top where the I put the plate on the frame rail humps, i used heavy duty liquid nails and them bolted it down at each corner.
8- I bought some fiberglass resin Jelly and spread it all around the outside of the PLATE!
9- I covered the PLATE with black velvet.
10- cut the interior pieces to fit.
I know that you guys think that this is a fiberglass box but it is a PLATE! I have heard Why dont you just make a box to fit.
I want all the space I can get because I built this car for road trips and I need every bit of space I can get.
All I have to say is PLATE PLATE PLATE, PLATE PLATE and oh yeah PLATE!!!!!
money spent on PLATE $50 proving plate haters wrong PRICELESS
It sound bad @ss
CAN DO -SEABEES
Thanks kid. I needed something to make me feel better about myself today.
Old Feb 14, 2007 | 04:03 PM
  #112
AmorgetRS's Avatar
I think this thread has run its course.
HP52TA
Feb 3, 2018 10:51 PM
bubbaz28
Sep 18, 2015 02:09 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
