Why Doesn't My Radio Keep It's Memory?
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
I have an aftermarket Pioneer head unit in my Firebird, and everytime I start the car, it acts as if the battery has been disconnected. I was trying to firgure out what was wrong, and I did discover that if I turn the car off, and then wait a couple seconds and then turn it back on, the radio keeps it's memory.
Any Ideas as to why this is happening?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Often, people reverse the ignition and battery wires.
The yellow wire on the radio needs a constant 12 volt source. I'm guessing that your factory wiring is hacked up because you wouldn't have had this problem if you used a $5 wiring harness, so your yellow Pioneer battery wire should be hooked to the orange GM 12 volt battery wire.
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
Jim is right the 12 volt constant is orange on the car harness and yellow on the pioneer harness, roughskinjrz the Blue wire is typically power out for a power antenna and such.
Kyle
Kyle
