going to re-wire my camaro
Old Mar 2, 2006 | 06:48 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
alright well my amp has been shuting off after being on for like 10-30 seconds and sometimes wont even come on, but works fine when its on. im pretty sure it is because of the power wire b/c i have 4 gauge power wire and it is crimped in the middle under the carpet. i want to go ahead and rewire the power wire. how much power wire do you think i should get to go from the battery to the amp and should i go back with 4 gauge or not? i have like 8 gauge ground wire i think. do you guys think the power sorce is the problem. i mean i have checked the remote wire and ground wire thats the only thing i can think of. other than a fuse in the amp or the in line fuse in the power wire. or do you think its something internal with the amp?
here is a pic of the setup. dont say anything about the amp i know it is sony and i like it. it looks nice sounds sounds good to me so it wont change.
http://www.cardomain.com/member_pag...135_17_full.jpg
Old Mar 2, 2006 | 09:42 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Check voltage at the amp with a multimeter. As long as it's getting 12 volts it should at least turn on.
Old Mar 3, 2006 | 06:03 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
You should be fine on that power wire, 8 gage ground is a bad idea, make that 4 gage too. Make certain that the ground has a good connection. If all is good with the ground connection, well, you may like Sony but bad solder connection are vary common.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
