Anyone just using deck power for the factory speaker positions?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Just wondering if any of you are using deck power to supplu aftermarket speakers in the factory loacations? I have Two Fosgate 10" speakers with a Fodgate amp in the well, just wondering if a 54 X 4 watt Sony would suffice for the rest of the car. Basically 22 Watts RMS X 4. I really didint want to get into another amp.
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
It will work fine but it's not going to sound the same as a nice good, clean amp. It's not going to make a major difference, it will just be one of those things. You won’t know the difference until you hear the exact same setup driven off an amp and the HU back to back.
Also, amps will be able to get louder and still sound good.
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
if i were u use the decks power for the speakers and if you get an amp use it for good like a sub or something then work on getting amps to the rest of the speakers like i did.
db057
Aug 11, 2015 10:11 PM
novaderrik
Aug 10, 2015 12:44 PM
