memory
Old Mar 19, 2006 | 05:25 PM
1bad88droptop's Avatar
Car: 88 camaro drop top custom
Engine: turbod lt1
Transmission: t56
memory
Im putting an aftermarket sony head unit in my rs and when putting it in i noticed that the cable for the memory did not connect right into the back of the radio, so when i adjust the radio settings and turn the car off all the settings go back to default. Whats up with this? Anyone had the same problem?
Old Mar 20, 2006 | 08:17 PM
Engine: turbod lt1
Transmission: t56
No one has a clue what im talkin about?
Old Mar 20, 2006 | 08:38 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
k you didnt hook up the players yellow wire right......
the yellow wire on the deck goes to the cars orange wire
k now dont get confused cause most do then......
the red wire on the deck goes to the cars yellow wire
that will fix your prob
Old Mar 20, 2006 | 10:03 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
sounds like you didn't hook up the constant
Old Mar 21, 2006 | 07:21 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The constant +12 volt battery wire in the car is in a separate plug and not part of the main radio harness. I hope that you used a wiring harness adapter kit instead of chopping up your factory wiring, but in either case, you're looking for an orange wire that's part of a separate 2-wire connector, usually on the right side of the radio compartment. Sometimes the orange wire is by itself with that 2-wire connector, other times it's accompanied by a brown wire. If you were smart enough to buy a wiring harness adapter, it should have come with the piece that this 2-wire connector will plug right into. If you hacked your wiring, hack this one too and connect it to to the yellow wire on your new radio.
Old Mar 21, 2006 | 10:34 AM
Engine: turbod lt1
Transmission: t56
alright thanks guys all try these things
Old Mar 24, 2006 | 09:30 PM
jamr0d's Avatar
Wow! thanks soo much i was having the exact same problem, and i was just about ready to post for some help... *** bless the search button!
Vintageracer
Sep 24, 2017 12:34 PM
Brother Al
Oct 14, 2015 06:39 AM
ZsTransAm
Aug 11, 2015 07:30 PM
MetKiss316
Car Audio
Dec 14, 2001 03:06 PM
