My project so far...
Old Apr 1, 2006 | 06:05 PM
lockchad's Avatar
Car: 88 camaro, black, T-tops
Engine: 305 5.0L
Well been working on it on and off for the last couple of weekends. So far i'd say i'm 75% to completion on the fabrication end. Lot of sanding to do still and I'm finishing with black gelcoat that i'm polishing. Let me know what you think...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Apr 1, 2006 | 11:25 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Nice work
Not a big fan of the door pods but the kicks look nice. Defiantly a very nice sub box but it seems a bit on the big side for a single 12” woofer that doesn’t have that much excursion. Any idea how big the box actually is?
Your pictures makes me want to go out and get some more work done on my car but I don't have the time to right now
Old Apr 2, 2006 | 06:07 AM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
what wires do u use to power speakers in door and in kicks i was told it was bad to run off other speackers.
Old Apr 2, 2006 | 11:51 AM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Love that hatch area
Old Apr 2, 2006 | 12:07 PM
lockchad's Avatar
Engine: 305 5.0L
thanks for the comments.
The speakers run on 14 ga wire and are solder tapped.
The door pods are being molded to the door panels when i start the re-upholstery (pops is an upholsterer).
The enclosure it double wrap. One 1.15cu inch enclosure is fiberglassed completely separate beneath the cover plate.
As far as looks I was debating on keeping the door pods. But as far as sound I can't imagine the car without them. It is perfect, phasing is right, soundstage is beautiful, and bass guitars never sounded so good. I do think though when i make new door panels i'll try to incorporate different pods.
Old Apr 9, 2006 | 01:22 PM
lockchad's Avatar
Engine: 305 5.0L
i'd like to have some feeback guys. i'm far from finished, and any ideas that you guys may have to make it better i'd like to try. thanks
Old Apr 10, 2006 | 12:05 AM
Gummie's Avatar
Car: 88 GTA
Might be a little late for this given paint on the kicks, but it looks like the tweeters are aimed at the bottoms of the seats. General rule of thumb is to aim more or less at the dome light. Also, depending on how far along you are with your door panels, why not aim the woofers in the doors some? On axis sound from a woofer generally sounds a good deal better than off axis. Also, I’m assuming that the woofers in the doors are running in sealed chambers?
I’m not sure what kind of input you’re looking for so I’m not really sure what to say.
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
