ground wire question
Old Apr 19, 2006 | 04:42 PM
pg29's Avatar
Car: 88 GTA
hi, im installing a new deck in my 1988 trans am GTA, but when i look at the wiring harness comming out of the trans am, i see two black wires with light blue stripes on them, are any of these the ground wire, the guy that had the car before me already cut off the connector. from the wiring diagrams i got from this site, it says black wire, but i don't see a solid black wire, just the smaller black wires with a light blue stripe. any help would be appriciated. thanks.
Old Apr 19, 2006 | 05:13 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
Throw an OMH meter on it. Check them for continuity.
Old Apr 20, 2006 | 07:10 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Putting an ohm meter on a potentially live wire is a great way to roach it. Never ohm out a live circuit.
What year and car are you working with. I can't find any Black/blue wires that should be nere there. Don't need to bother though. If the ground is the ONLY one you're having problems with, take the HU's ground right to the chassis. Find a good spot, clean it good, make good connection, go on with life.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
