Eclipse?
Old Jun 9, 2006 | 08:14 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Eclipse?
I'm looking at installing a better system in the bird. I have a local shop that sells Eclipse, and since I have had one of their products before, I would like to use some more of their products.
Starting at the front, I will be using an Eclipse CD-3492 (I think that's what it is, it's last year's 34XX series) or the new CD-3000 (50Wx4, CD/MP3, 5V preamp). I will also be buying the 21010 crossover (5-band) to tone down my front speakers (the highs are too high for ALL of the speakers I've tried). At the back, I am planning on running their XA1000 subwoofer amplifier (640W peak, 480W@2ohm RMS, 320W@4ohm sub channel). Now, as for subs, I am currently looking at a pair of their SW4000 or 4200 subs. The 4k's are 10" (200W RMS, 600 peak, requires 1.25 Ft air space), and the 4200's are 12" (250W RMS, 750 peak, requires 2.75 Ft air space). However, the sub box I am planning only has room for two tens unless I modify the design (and make it harder to build). Does anyone recommend anything different? I have yet to decide on 4x6"s and 6x9"s, which I will also upgrade. I need the 6x9's to have a decent bass kick (assuming I stuff the factory boxes with polyfill) since I will be removing the system when I return to school next fall (got broken into once, not letting that happen AGAIN! ).
I am NOT looking to spend $3k on a system, BTW, so no Infinity Kappa plates or anything like that.
Old Jun 9, 2006 | 08:29 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
i am a selective reader so i didnt read everything but eclipses are awesome. My friend had 2 sony xplod suposedly 1200 watt 10's and he returned em and got two 10" eclipses and they were loud as anything almost. He had a crappy 200 watt amp too.
Old Jun 10, 2006 | 07:32 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Just a correction on the above post:
The other headunit I am considering is the CD-5435. I don't know the specs on this as of this moment.
Still looking for suggestions...
hot86z-28
Car Audio
16
Dec 21, 2001 11:23 AM
redcamaro83
Car Audio
Aug 6, 2001 03:39 AM
termite85iroc
Car Audio
Feb 28, 2001 06:55 PM
85ws6TA
Car Audio
25
Dec 16, 2000 05:24 PM
