power antenna not working, did search
Old Jul 23, 2006 | 11:19 PM
PAformula's Avatar
After searching the boards I haven't found an answer to my problem. I put a used power antenna in my fiance's '88 GTA and it worked about 3 times, now it stuck down and doesn't move. I can hear the relay click when you power on the radio and I think I hear the antenna make a "clunk" but can't be sure until I have someone listen by it. Any ideas?
Old Aug 14, 2006 | 01:35 PM
KRUSS's Avatar
Car: 1992 Arctic White Z28 Convertible
Engine: LB9 305 cid TPI
Transmission: 4L60
Axle/Gears: B-W 7.75" 3.73
Power Antenna Repair
Quite often it is the nylon gear that meshes with a nylon "cable" that breaks (wears-out), making the antenna inoperable. They make rebuild kits for these antennas but I'm not sure how to go about it since I've not yet had to conduct this repair yet.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
