Memory???? whats that ... lol
Old Aug 11, 2006 | 02:49 PM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
hey guys.... i gotta new head unit ....... but not sure which one is the memory wire..... theres a yella and 2 blue ones... not sure which is which... and the memory wire in my wiring harness for the car is shot out so i know that i need to runa wire to the fuse panel..... which fuse should i run it to????
Old Aug 12, 2006 | 11:47 PM
85T/A's Avatar
come on this is the Car Audio page... ive seen some pics of systems on here somebody has to know
Old Aug 13, 2006 | 05:25 AM
AllenGTA's Avatar
Car: 1987 Camaro Z28
Engine: 5.0 TPI
Personally, I ran a new supply from the battery to the radio with an inline fuse. Otherwise you shouldbe able to find out from a wiring diagram. Sorry I can't be more help.
Old Aug 13, 2006 | 10:55 PM
85T/A's Avatar
thanx dude.. appreciate it.. any other ideas..???
Old Aug 14, 2006 | 06:07 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
You're not getting a lot of response because this has been gone over, a lot. This was linked to right out of the tech article section of this web page.
http://www.geocities.com/vtcamaro/Pi...rams/pg225.jpg
In the car the B+ (hot all the time/memory) is Orange, for aftermarket HU this will connect to the yellow wire.
You need 12V on this wire all the time. If you don't have it, fix that. We usually fix problems, not cover them up.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Vintageracer
Sep 24, 2017 12:34 PM
383backinblack
Oct 14, 2015 08:50 PM
HoosierinWA
Oct 7, 2015 10:15 AM
