Vibrating rear bumper
Old Oct 19, 2006 | 10:01 AM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Hey,
I just installed 2 12 inch subs in my car. Everything is really tight and at normal listening volume there are no vibrations. If I turn it up really high then I can hear my back bumber vibrate. I know its not my plate, I have that dynamated. Does anyone else have this problem? How would I go about making it stop? Thanks
Old Oct 19, 2006 | 10:14 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Dynamat the bumper too. Removing it isn't that difficult.
Old Oct 19, 2006 | 10:22 AM
Car: 1991 Camaro RS
would it be the bumber itself vibrating or the part where it attaches to the car? is there any material you would reccommend for the part where it attachs?
Old Oct 19, 2006 | 01:20 PM
Jim85IROC's Avatar
unless your bolts are loose, it's not where it attaches. It's the big flimsy piece of urethane vibrating against the foam insert behind it.
Old Oct 19, 2006 | 01:33 PM
Car: 1991 Camaro RS
thank you. ill look into this
Old Oct 23, 2006 | 01:57 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Mine did that. I took the cover off and it was wicked rotten behind it!!
Old Oct 27, 2006 | 06:37 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
not just a little rattle i get the same thing from my single solo baric. and i changed my bumpers and its complete fine back there just take it off put it on the back on the inside of the bumper and itll stop
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
mikey8494
Aug 22, 2015 07:57 PM
