porting sealed box
Old Nov 1, 2006 | 02:58 PM
liquidrider3214's Avatar
porting sealed box
hey everyone i have this box Top Edge - Detail with two alpine type e's powered by an mrd 605 amp the box is 1.92 cu ft a sub, so i was wondering if i could port the box and how i would do so i looked up how to tune the box and found out that to tune a port to 35 hz with 1.92 cu ft of airspace i would need to make 1 3" port so how could i do so? just take a 3 inch holesaw and cut it out?
Old Nov 1, 2006 | 03:17 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
No. Any sealed box that's built to the proper specification will be WAY too small for a ported application using the same driver. For any given driver, a ported alignment will be substantially larger than a sealed setup.
Old Nov 1, 2006 | 03:52 PM
according to alpine 1.92 cu ft ported is plenty big ported but sealed it is too big so instead of changing my custom box i would rather change it to ported
Old Nov 2, 2006 | 07:04 AM
Jim85IROC's Avatar
then cut the hole, add your port, and have a blast.
Old Nov 2, 2006 | 10:03 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Did this also show you the length of the port? That is just as important as the diameter. I wanted to port my box, but found out I would need a 3" dia. port, with a 19 inch long tube. Not happening in this trunk.
GTAman
Jul 3, 2024 07:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
roysatikas
Sep 7, 2015 08:08 PM
