Choosing the right Amp?
On Probation
Car: 1992 Pontaic Firebird
Engine: 3.1L
Transmission: auto
Axle/Gears: 4 spd
i dont really know much about audio so i may sound stupid! i just bought 2 brand new 10'' bazooka's from a freind. he threw in an amp along with the deal for a total of $70. but, he said the amp is pretty weak(2 channel 150 watt). on the specs chart of the sub packaging it says the bazookas can handle 200 watts each. so does that mean i should try to get and amp that can handle 400 watts? i have know idea what is ideal with audio so someone help me out.
Car: 89 camaro RS convertible
Engine: 305 tbi
there are
2 C on the amp an +- for the right and a +- for the left briged is where u take the right and left + and put them to gether and put them on the right +on the amp. then take the right and left - and put it on the left - on the left
does that help with what briged means
Last edited by diablo666mew; Nov 26, 2006 at 11:09 PM. Reason: Automerged Doublepost
On Probation
Engine: 3.1L
Transmission: auto
Axle/Gears: 4 spd
there are
Engine: 305 tbi
ok i will try harder lol on an 2 channel amp. there are two spots for each sub with make 4 spots one is a - then a + for the ther right sub and the same for the left that is where you would put the - and + wire for each sub see 4 spot - and a + left - and + right a brig is where instad of hooking up the wire like u shold u take the left and right - wire and put them together and put the on the left side - on the amp hook up the u take the right and left side + wires and put the on the right side amp + hook up figger it out yeat i no kind of hard to under stand
Car: '85 Z28
Engine: Need one. =(
By the way, you may want to shorten up your sig a little bit - it's gigantic.
raymondandretti
Sep 27, 2015 06:43 PM
