amp troubles
amp troubles
so i am running(or at least trying to) a concord 100 watt amp for my main speakers. It turns on and everything. When i first installed it it powered all 4 of my speakers just find, but then it started to shut down after a while. Then it would start to shut down with all 4 spekaers n no matter what. So then i only ran 2 on it and it was fine for a while, and now it shuts down even at super low volumes, icant figure out why. I also have a punch 45 on my sub and i can crankup the volume all the way and it gets all the power it needs and runs fine. This leads me to beleive that there is something worng with the amp.
i checked for voltage drop as i tunred the amp on and increased the volume, and there was none.
If anyone has any suggestions they would be greatly appreciated.
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
make sure none of the wires are touching... if a hot wire and a ground touched it could do that...
raymondandretti
Sep 27, 2015 06:43 PM
