How much is too much?
Old Mar 19, 2007 | 06:40 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Well the time has finally come which I can begin spending money on my car again. I've decided to replace the crappy 2 channel amp I have powering my 6.5" Alpine Type R components with a 4 channel to power the components as well as the Alpine Type R 6x9's in the sail panels.
My question is this: how many watts over the RMS power can you go without potential hazard to the speakers. I realize the RMS rating is the rating which is recommended for optimal performance from the manufacturer. The amp I was thinking about going with would give each of these speakers 100 watts RMS. The components are rated at 70 watts RMS while the 6x9's are 55 watts RMS.
I've heard of guys running components rated at 50 watts RMS with over 100 watts RMS. Is this crazy, or typical? I've always played things pretty safe with wattages but now I'm wondering if I'm too critical.
Old Mar 20, 2007 | 10:27 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
Re: How much is too much?
you can run almost as high as you want.. of course your not gonna use a 3000watt amp for your 50 or 75 watt compnents.. but as long as you keep the gain turned down it will be fine
Old Mar 20, 2007 | 09:49 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
even if your gain was turned down and u had a 3000 watt amp hooked up to 50 watt components, something is wrong with you. lol.
Old Mar 21, 2007 | 04:42 PM
TheBandit's Avatar
Engine: Poncho 350
lool.. i know that was just saying... it doesnt hurt to have more power..
Old Mar 22, 2007 | 07:53 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's no harm in having extra power available, but often there's no benefit either. In most conventional cases that have the component speakers running 80hz and up, a 50 watt amp will be sufficient to keep up with almost any reasonable amount of bass.
Old Mar 22, 2007 | 09:12 AM
Epsilon2k's Avatar
Car: 1992 RS
Transmission: Stock Auto.
Axle/Gears: Stock
But then again, you could just get some higher rated speakers too.
Old Mar 22, 2007 | 10:19 AM
Jim85IROC's Avatar
That does you no good unless you're currently having problems keeping up with the bass. Any competent pair of components powered by a 50 watt amp should keep up to a normal pair of 10s or 12s.
If you buy a pair of speakers with greater excursion capabilities and greater power handling, then with more power you may get more output unless the greater excursion capabilities came at the expense of sensitivity. Making something louder involves a lot more variables than amp output and speaker power handling.
