rear speakers not working
Car: 1984 Trans Am
Engine: LG4
My telescoping antenna has a problem and is stuck in the up position.
My dad disconnected the wire that goes to it, but now the subs dont work when you hit the music button on the dash.
Does the fender have to be removed for the antenna to be fixed, and if so, is there another way to wire the subs so that they work when I hit the button?
He said that the problem is not the antenna motor, it is a cable or something.
Easy fix?
Easy fix?
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
Re: rear speakers not working
pleae take out your radio again and check your wiring , make sure all connections for your pre outs are good
and for the antenna i dont think the fender has to come off and i dont think its that hard it might just be a wiring running from fender to firewall to dash some were , i havnt realy looked tho
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Easy fix?
Easy fix?
R u using the ant wire as a remote wire?(for the amps)
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
db057
Aug 11, 2015 10:11 PM
