PICS 11/2 DIN - 1 DIN ADAPTOR
Car: Camaro RS 1991 305 TBI
Engine: 305 LO3
Transmission: automatic
Axle/Gears: stock
Hi, guys i need this pics because here in Caracas,i dont find it
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: PICS 11/2 DIN - 1 DIN ADAPTOR
One for Camaro on Crutchfield. Cut the supports for shaft mount radio and your 1-DIN will fit.
http://www.crutchfield.com/S-xuNQseV...t&i=120923008P
You might want to check out a humount first. I think you might need to modify them to make them fit, but they're the right size to fill in the opening and look a lot better. You can probably find some info on them if you do a search.
Edit: I just realized that you just ask for pics, but still, check out http://maptechenterprises.netfirms.c...ad545c67d3ca64
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
