Short somewhere in the power antenna circuit
Old Jul 7, 2007 | 02:30 AM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
I went to school on Thursday morning listening to the radio and all was well. When I got back to my car to go back home in the afternoon, I turned on the head unit, expecting to hear the radio, and there was no sound. Then I noticed that the power antenna was not up. I could not hear anything no matter what volume I set the head unit at. I figured the amplifiers did not turn on. So if the amps didnt turn on and the antenna didnt go up, then something was wrong with the remote wire. I took out the head unit and the back metal part was too hot to hold. I disconnected the power antenna and amplifier cables from the remote turn on wire in the head unit. I first tried connecting only the antenna to the remote wire and it didnt go up. Then I connected the amplifier wire to the remote wire and I finally hear music
So its my power antenna that has a short somewhere. My guess is that the relay failed. Does a failing relay cause what I described above? Also, if it is the relay, is it readily available at any auto parts store?
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
