OEM Radio Troubles
Old Sep 22, 2007 | 12:55 PM
poppn's Avatar
Car: '85 Firebird, '74 Nova
Engine: 2.8, 5.7
Transmission: T5, TH350
Axle/Gears: 3.42 open, 3.08 open
OEM Radio Troubles
my '85 came with the premium radio option, but the radio is acting a bit wacky. sometimes the radio works fine, other times when the radio is on there is nothing but static as if the antenna wasn't plugged in at all, and then sometimes the radio with just shut off even though the power button is pushed in but the time and everything is still displayed, but it's like the radio doesn't react to the power button. i've pulled the radio out and checked the connections, all is good. is there a bad ground somewhere or is the radio just about to ready to die? 'It sounds confusing, i know lol
Radio Works
Radio Works but no reception, only static
Radio shuts off and doesn't react to power button.
Old Sep 22, 2007 | 02:15 PM
aceman1's Avatar
Car: 1989 camaro
Engine: 2.8
Re: OEM Radio Troubles
pull it out and make sure the wires on the back are not touching each other. i had that problem and it was the wires touching.
Old Sep 23, 2007 | 02:01 PM
poppn's Avatar
Engine: 2.8, 5.7
decided to just use an old sony head unit and buy the harness adaptor for it. thanks anyway though
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
