system setup questions
Old Oct 28, 2007 | 08:19 PM
GTAPresto's Avatar
Car: 1987 GTA T/A
Engine: 350 V8
Axle/Gears: rebuilt stock ratios
ok so I took the system out of my TA and am stickin it in my daily car which is a 2001 Hyundai Tiburon
I have:
a pair of sony 10" 1080 watt peak power sub woofers
a SPL Series 2 ZSX-820 820 watt bridgeable amp
JVC KD-S590 head unit
power cable with fuse
line out cables
Other than some speaker wire is there anything else i would need? what i did was just take everything out of the TA minus the speaker wire. Also, is there a part I would need to use the original head unit? Or would it be best to get one that would fit in the space? Would it be a good idea to get another battery to stick in the back? Any help is appreciated. Thanks
Old Oct 28, 2007 | 08:37 PM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
Re: system setup questions
you need a line out converter to make the factory radio work, a good one won't be cheap, and a cheap one sounds like crap, I prefer the new radio when possible (that's me though) an extra battery is just another load on the electrical system, and only helps with key off run time. A kit for the JVC is pretty cheap, you'll also need a harness for the radio
Old Oct 29, 2007 | 10:11 PM
GTAPresto's Avatar
Car: 1987 GTA T/A
Engine: 350 V8
I'd prefer the new HU too but im just worried that ill have a hard time getting it to fit flush. The Tiburon has a CD and tape deck and the whole thing is like 3x as big as the JVC. I've heard something about a dash kit? If anyone knows about those?
Old Oct 29, 2007 | 10:19 PM
chevrolet87's Avatar
yea a dash install kit, you should be able to get them at any audio store around you. Its easy, the radio slips in the hole then you clip it into place and then you done.
Old Oct 30, 2007 | 12:13 AM
GTAPresto's Avatar
Car: 1987 GTA T/A
Engine: 350 V8
sounds cool, i guess i need to make a trip out to crank it up.
MustangBeater20
Oct 29, 2022 09:20 PM
Street Lethal
Apr 30, 2019 12:14 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 13, 2015 08:28 PM
jahblah
Aug 12, 2015 05:54 PM
