89 Turbo Trans Am radio problem
Old Nov 18, 2007 | 05:39 PM
The Banana's Avatar
Car: 71 Trans Am and 89 Turbo Trans Am
Engine: 71 TA is very fast street car. 89 TA is completely stock w/58k miles
Transmission: 71 has TH400
Axle/Gears: 71 has Ford 9" w/31 spline and spool
I have an 89 Turbo Trans Am with the stering wheel controls. Recently the sound to the speaks seems to shut off but I can still hear a little bit of hissing noice. It seems like there is a factory amp, relay or some other device that seems to click off or has a loose connection. Without warning the sound will kick in and out without rhyme or reason.
Has anybody delt with this issue or have any ideas as to what could be causing the problems?
Any input would be helpful. Please email me at dwayne@3dstreetracing.com
Thanks,
Dwayne
Old Dec 10, 2007 | 10:49 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Re: 89 Turbo Trans Am radio problem
Sorry I didn't see this sooner. I'd check all your speaker/headunit wiring, you probably have a loose connection somewhere.
Old Dec 12, 2007 | 02:05 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Unless you hard wired a sirius unit into your acc power or FM antenna (like me), it would have no bearing on audio output from the factory head unit.
Old Dec 12, 2007 | 02:28 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
don't those have the bose systems ... Have a friend with a 90 vette his did that when his amps died
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
